Thread: Rear caliper bracket problems!
  1. Rear caliper bracket problems!
    Sep 2020
    Taunton
    I am having problems removing the 8mm allen bolts for the rear caliper brackets. I have tried wd40 with a lot of hammering. Dare not try a breaker bar as at least one of the 8mm allen bolts looks a little stripped. Do you think a little heat persuasion would help? I'm kinda thinking to leave them alone but would like to get them off so any future work will be easier. Thanks
  2. Re: Rear caliper bracket problems!
    Near Blackpool
    48 Post(s)
    Innotec deblock oil is quite good. Also a really well fitting Allan key socket.
  3. Re: Rear caliper bracket problems!
    108 Post(s)
    1816 Post(s)
    We often have to employ the hot spanner but you will not have access to this. Obviously the bolts must be replaced, part number N 907 403 02 and £1.37 each. Brand new genuine OE TRW caliper carriers for the typical solid disc Golf 4 are only £30 each from *******, part numbers BDA589 and BDA590.
  1. Replies: 4
    Last Post: 02-04-2018, 12:59 AM
  2. Please Help Sourcing Front Brake Caliper Bracket/Carrier
    By Lidunian in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-09-2016, 03:29 PM
  3. Rear Caliper Carrier Mounting Bracket Bolt Specs!
    By manfromconnacht in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-02-2012, 07:30 PM
  4. Rear caliper problems - help
    By shabazmo in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2012, 10:58 PM
  5. Front DS caliper mounting bracket
    By Canetoad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2010, 11:30 AM
