Thread: Michelin tyre pressure advice (Winter)
Results 1 to 9 of 9
  1. Michelin tyre pressure advice (Winter)
    Mar 2007
    Lancashire
    This one really confused me, it's direct from Michelin website.. read on......
    Inflating tyres in winterWhen it's cold, tyre pressure registered on a pressure guage can seem lower than it really is.
    For example, if a tyre is inflated to 2 bars at an ambient temperature of 20°, the pressure can read 1.9 bars on a manometer in an ambient temperature of 8°C.
    This phenomenon can be misleading, and does not necessarily indicate that the tyre is under-inflated. It is not therefore worth inflating your tyres more in winter.
    Surely if the outside temperature has dropped the tarmac is cold and thus the tyres will no get up to summer operating temperatures. I've read the opposite if anything; inflate a little more in Winter... I'm a little confused about Michelin's claim.
    If it's say 7c outside I would inflate to 34psi as I would if it was 20c! Anyone have any thoughts on this?
    Marco
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  2. Re: Michelin tyre pressure advice (Winter)
    Sep 2007
    carlisle
    Hi Marco34,
    i`m with you on this one, if the tyre side wall says inflate to xxxx pressure then this means all year round !!!!!!!!!!!!!!
  3. Re: Michelin tyre pressure advice (Winter)
    Dec 2006
    Manchester
    The cold air is more dense than the warm air of when the tyre is in use.....
    As the tyres do there job they heat up, and in turn, the air inside expands, increasing the pressure inside the tyre to it's normal running temp and pressure.
    If your staring from cold, the air will heat up more and thus expand more.
    Well, thats my opinion of it anyway!
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  4. Re: Michelin tyre pressure advice (Winter)
    Dec 2006
    I would say just put what ever PSI you normally put in and take it from there...
    Thats what i do anyway..
    Rick
  5. Smile Re: Michelin tyre pressure advice (Winter)
    X
    Im with marco34/ faticus on this one.The information on the sidewalls is there for a reason.
    Tyre companies spend millions every year on R and D for good reason.
    They want us to buy the products they manufacture,if they dont work we dont buy
    Speed ratings are important with different vehicles/conditions etc.
    To be honest I choose the make first and buy the best I can afford (a nice tread pattern always helps)
    One final thing always warm them up first IT MAKES SENSE
  6. Re: Michelin tyre pressure advice (Winter)
    Canada
    Quote Originally Posted by Marco34 View Post
    Guys I think you missed the important bit, when its cold the gauge under reads, nothing to do with air temp in tyre etc etc.it just 20psi will read 19psi on the gauge
    but i wouldn't worry to much, as pertol station air pumps can be at least 1 psi out
    VW Tiguan 4motion 2.0T 2015 - Awesome snow churning 4x4 GTI 😉
  7. Smile Re: Michelin tyre pressure advice (Winter)
    Sep 2007
    carlisle
    onzarob, hi do you really believe the gauges on petrol forecourts ?????????? personally i use a digital one from halfords- does me-34psi in winter or summer. not a tyre fitter so don`t know the technical ins n outs of this
  8. Re: Michelin tyre pressure advice (Winter)
    Canada
    Quote Originally Posted by faticus View Post
    Generally no...some I do but thats because I double checked them with my gauge
  9. Re: Michelin tyre pressure advice (Winter)
    Mar 2007
    Lancashire
    Quote Originally Posted by onzarob View Post
    A gauge should read the same weather it's at -20 or +20 surely. The mechanics of a gauge shouldn't change. I use a halfords dial gauge, very accurate. Michelin's point is that the air inside a tyre is the same at 20 or 7c. The molecules are cooler at 7c so less in size. If my tyre got to the same temps as they do in summer then the inflation would be the same. I agree on that, but, with cold air temps and cold tarmc my tyres only gain 2 psi on a run unlike 3-4 in summer.
    Re-map by more-bhp.
  1. Audi 2.0 Avant winter tyres rim sizes, pressure
    By pluggy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-11-2007, 08:55 PM
  2. Tyre Pressure - 03 Passat
    By kavassery in forum Passat - Archive Topics
    Last Post: 31-08-2007, 12:03 AM
  3. Touran Tyre Pressure
    By aussie in forum Touran - Sharan - Caravelle
    Last Post: 10-07-2007, 05:06 PM
  4. Just gone to 17" what should my tyre pressure be?
    By ldormon in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-03-2007, 08:34 PM
  5. Tyre pressure gauge
    By Mav2006 in forum Archive posts
    Last Post: 28-03-2007, 07:32 PM
