Thread: 2013 C7 A6 Avant - MMI & Bluetooth Issues
  1. 2013 C7 A6 Avant - MMI & Bluetooth Issues
    Jan 2020
    Yorkshire
    On a recent trip the bluetooth on the car has just stopped working. The start of the 5 hour drive, my iPhone connected to the car and I was able to make calls as normal.
    Approx. 3 hours in I went to make another call and the phone wasn't connect, nor would it reconnect - The bluetooth was switched off, no bluetooth name was showing and no list of paired devices. I've performed a factory reset and a system restart - still nothing. My local Audi specialist has run diagnostics and upgraded the firmware - still nothing.
    When you first start the car, the bluetooth logo shows for a few second then the bluetooth shuts off. Turning it back on causes the system to lock up for a few second, the bluetooth turns on and allows you to search of devices but it doesn't find any, nor can you find it with any devices - the device name on the car still remains blank. After 20 or so seconds the bluetooth shuts off again.
    Everything else runs as it should - satnav, DAB etc. Only issue I've seen over the last few months is a handful of random restarts of the MMI system when driving.
    My local specialist have diagnosed it as a faulty MMI/RMC unit - A cost of £2000! They have suggested that if I sourced the part myself they'd be happy to code/remove component protection. Part code 4G0035192H. An ebay search shows units at circa £200 plus £120 coding from my specialist.
    My questions are:
    - Has anyone else seen this? Is it common?
    - Is there anything else I can try?
    - What are the thoughts of new vs an ebay unit?
    - Other then ebay, is there any where else I can try for a new/refurb/used unit?
    - If I'm going to pay £2K, is there an upgrade I can do at the same time given the original unit is showing its age?
    Car is a 2013 Pre face lift C7 A6 Avant black edition with the standard fit MMI/Nav unit.
    Thanks in advance!
  2. Re: 2013 C7 A6 Avant - MMI & Bluetooth Issues
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    I had this on an Android fone, just stopped working, tried everything, in the end I fixed it. I bought a new fone.
  3. Re: 2013 C7 A6 Avant - MMI & Bluetooth Issues
    Jan 2010
    Yate UK
    17 Post(s)
    If it's just the bluetooth that's gone pop I would go for something like this:
    503 - Service Unavailable Error
    £20 fix rather than £200 or £2k. Not perfect I'm sure but a lot cheaper.
    Now: 2016 C7 2.0TDi BE with Tech Pack, magic parking, ambient lighting
    Previous: 2013 C7 2.0 TDi S Line
    C6 2.0 TDI LE
    A4 2.0 TDI SE
    and an ancient 80 in the olden days...
  4. Re: 2013 C7 A6 Avant - MMI & Bluetooth Issues
    Jan 2020
    Yorkshire
    Quote Originally Posted by Whippy53 View Post
    It’s definitely not the phone. Tried all different types of phones both IOS and Android.
  5. Re: 2013 C7 A6 Avant - MMI & Bluetooth Issues
    Jan 2020
    Yorkshire
    Quote Originally Posted by nevbadger99 View Post
    Had thought about that, or a decent set of wireless headphones. I travel a lot for work so having a decent hands free in the car is a must really - obviously given COVID it’s not an issue at the moment, more an annoyance.
  1. Question 2013?Audi A4 Avant 2.0 TFSI
    By Donmeister in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-06-2016, 08:52 PM
  2. 2013 A6 - Bluetooth problems
    By abuelbanat in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 31-03-2016, 08:37 AM
  3. Question 2013 Audi A6 C7 Avant
    By wizzygti in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 03-01-2016, 03:52 PM
  4. Fuse Map/Diagram for A6 Avant 2013
    By lloydtown in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-01-2014, 09:46 PM
