Thread: A3 1.6TDi water pump
  1. A3 1.6TDi water pump
    Sep 2019
    Coventry uk
    8 Post(s)
    Hello I have recently changed the timing belt, aux belt and associated pulleys plus the water pump on my A3 convertible. The engine code is CRKB. However I think I have a very small coolant leak from the new fitted water pump. The pump relies on a rubber seal and compression so no gasket compound required.
    In all the guides I could find there is no mention of the torque values for the three bolts.
    Hence they are tight. Can anyone let me know the correct values as I suspect it will taken back out in the next week or so.
    Many thanks
  2. Re: A3 1.6TDi water pump
    1835 Post(s)
    I did a new genuine belt kit and pump on my Octavia, reluctantly as it was 6 years old but only 20K, and now I have a leaking water pump. The torque is 20Nm+45° and they are TTY on time only, part number N 910 488 04; 67p each.
  1. Question 1.6tdi mk7 heater pump blocked
    By kicky1 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 27-09-2018, 08:54 PM
  2. Golf 1.6TDI Seized water pump
    By Stanhope in forum Golf MK6 - 2009 - 2013
    Last Post: 20-04-2018, 08:12 AM
  3. Important caddy 1.6tdi secondary air pump location
    By luigino007 in forum The Commercial Range
    Last Post: 06-12-2015, 07:56 PM
  4. Replies: 2
    Last Post: 06-03-2015, 12:01 PM
  5. Water Pump on a 1.6tdi mk6 Golf
    By matthew2riches in forum Golf MK6 - 2009 - 2013
    Last Post: 30-06-2013, 08:07 AM
