Thread: Golf Mk 4 - Noisy starter motor overrun - help please
  1. Golf Mk 4 - Noisy starter motor overrun - help please
    Sep 2020
    milton keynes
    Symptom: Car starts well but immediately after starting there is a loud screeching vibrating noise from the starter motor for about 1-2 seconds (enough to wake the neighbours). Today I removed the starter and tested it expecting to see some wear or slow retraction of the pinion. It all looks good though. Bendix snaps out rapidly and snaps back strongly once the power is removed.
    So i thought, maybe the starter switch. Tested that. Power to solenoid goes off immediately the key is let go. So that gets a tick.
    I have a look at the bendix gear. A bit worn but no obviously major fault. Had a feel around the ring gear on the flywheel. A bit worn too. Little sharp in places on the outer edge. I doubt this is preventing disengagement as would be sloppy if anything.
    So finally i am out of my depth and stumped. The whole car cost around £750 so don’t really want to start replacing parts ar random.
    I’m merely hoping someone on the forum has had a similar issue and can point me in the right direction.
    If not, then many thanks for bothering to read my post anyway!
  2. Re: Golf Mk 4 - Noisy starter motor overrun - help please
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Something settling down on the flywheel maybe? We get a screeching noise at certain revs / gears that I'm told is the DMF not being very happy.
  3. Re: Golf Mk 4 - Noisy starter motor overrun - help please
    1840 Post(s)
    They do it, my Octavia 1.8T goes through phases of it, replace the motor or keep annoying the neighbours. I am converting my car to six speed so I am fitting a new starter.
  4. Re: Golf Mk 4 - Noisy starter motor overrun - help please
    Sep 2020
    milton keynes
    Thanks for your replies. This morning I noted that the starter makes the same noise after letting go the key, even if you don’t turn the engine long enough to actually start. So I am coming back around to seeing this as definitely a fault with the starter itself. Bearings?? Or maybe the motor keeps running after the bendix is disengaged. From the sound it is worn out anyway.Will probably replace in due course.
    Many thanks again
  1. Please Help noisy new starter motor polo 6n1 1.9 diesel
    By madbypolo in forum Polo - Derby - Lupo - Fox
    Last Post: 15-01-2011, 09:15 PM
  2. Question Starter Motor Golf 1.6
    By Loughers in forum Golf MK4 - 1999 - 2004
    Last Post: 19-01-2009, 10:44 PM
  3. Golf MK4 starter Motor Number
    By Ewster in forum Golf MK4 - 1999 - 2004
    Last Post: 21-01-2008, 09:28 PM
  4. Starter motor noisy on cold mornings
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-11-2007, 12:25 AM
  5. Starter motor for Mk3 Golf TDi
    By j_coupland in forum Golf MK3 - 1993 - 1999
    Last Post: 16-04-2005, 08:13 PM
