Thread: Spinning captive
  1. Spinning captive
    Feb 2014
    Oxford
    7 Post(s)
    Trying to remove the OSF supension strut from an MK4 Golf but two of the top bolts are just spinning and it looks like the threaded inserts in the strut itself have come loose. Anyone seen this before? I can't get hold of the inserts with anything to stop them so it looks like I'm going to have to try to cut the heads off, somehow??!!
  2. Re: OSF suspension strut - top bolts spinning?
    1840 Post(s)
    Top bolts? Golf 4? The Golf 4 top plate is retained by a nut in a plate, this sounds like a Golf 5.
  3. Re: OSF suspension strut - top bolts spinning?
    Feb 2014
    Oxford
    7 Post(s)
    Yes ok it's a 60 plate so a MK5, my bad ...
    I'll move this across later
  4. Re: OSF suspension strut - top bolts spinning?
    1840 Post(s)
    Golf 6 if it is a 60 plate, this happens with the PQ35 type top mount and we deal with it using vice/mole grips from below.
  5. Re: Spinning captive
    Feb 2014
    Oxford
    7 Post(s)
    Well I wasn't so lucky, even with the insert in the vice I still had to cut the remaining top portion of the bolt off and wind the insert up and off it that way, there was no way it was going to come off the normal way, it was no wonder the inserts came loose. It was relatively easy to press them back in and punch round them to make them stay put though.
  1. 2009 A3 1.9D Spinning Noise
    By cb1 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-02-2016, 10:58 AM
  2. spinning key
    By arnieboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-05-2013, 10:39 AM
  3. Question Should The Cooling Fans be spinning when . . . .
    By Bigwizzard in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-09-2011, 10:47 AM
  4. Spinning down noise when lifting off
    By brido in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-10-2010, 08:23 PM
  5. Important **FAN NOT SPINNING! Please Help - Audi A3
    By Nza in forum Audi A3 - Archive Topics
    Last Post: 08-09-2008, 01:56 PM
