hi,
i have problem with my slidings doors.
Code:
Address BF: Slid. Door Rear Right (J731)
1 Fault Found:
52480 - Crash Shut-Down Activated
  P1609 00 [137] - -
                    Voltage terminal 30: 12.2 V
                    Sliding_Door_Motor_Current: 0.0 A
                    Sliding_Door_Clutch_Current: 0 A
                    Sliding_Door_Locking_Pawl_Motor_Current: 0 A
                    Front button for automatic sliding door: not activated
                    Rear button for automatic sliding door: not activated
                    Installed on left side: No
                    Installed on right side: Yes
                    Pinch protection sensor: not activated
                    Latch_Ajar: operated
                    Latch_Pawl: operated
                    Sliding door indicator lamp: not active
                    Sliding door indicator lamp 2: not active
                    Activation: motor for automatic sliding door: not active
                    Automatic sliding door coupling motor activation: not active
                    Motor activation for enabling ratchet release: not active
                    Sliding_Door_Feedback_Motor_Opening: not active
                    Sliding_Door_Feedback_Motor_Closing: not active
                    Sliding_Door_Feedback_Locking_Pawl_Motor_Opening: not active
                    Sliding_Door_Feedback_Locking_Pawl_Motor_Reversing: not active
                    Sliding_Door_Feedback_Clutch_In: not active
                    Sliding_Door_Feedback_Clutch_Out: not active
                    Sliding_Door_Feedback_Indicator_Light_Front: not active
                    Sliding_Door_Feedback_Indicator_Light_Rear: not active
                    AD-Value clamping_Protection_Seal: 99
                    Position of automatic sliding door: 0
                    Status_Sliding_Door: latch secondary position
                    Play protection: motor for automatic sliding door: not active
                    Play protection: motor for enabling ratchet release: not active
                    Play protection: automatic sliding door coupling motor: not active
                    Status_Locking_Pawl_Motor: closed
                    Status_Clutch_Motor: Open
Address BE: Slid. Door Rear Left (J558)
1 Fault Found:
  P1609 00 [137] - -
Someone have the procedure?
I followed a tutorial on the net but I do not have the codes to access the following menu either
"security access - 16"
