Thread: A3 2.0tdi cff keeps cutting out
  1. A3 2.0tdi cff keeps cutting out
    Sep 2020
    Plymouth
    Hi new to the group and looking for help.
    2011 a3 2.0 tdi sline
    Only had the car for 6 weeks and it was running fine then all of a sudden it has started cutting out wile driving. It seems to bump start if the car is still moving but if the car comes to a stand still all the ignition power goes off for about 10 minutes (radio and lights all work still) then it will start and idle as if nothing has happened. It happened last night and had to call the AA out tried diagnostics and their are no codes stored and no lights on the dash, he went through it and tried pulling every relay under the bonnet and in the drivers foot well and the dash lights didn't go off as it would when I was driving it, to get the car home he tried a temporary engine earth which did get the car home but it did cut out twice on the short drive back. Does anyone know of anything else I could try or anybody in the Plymouth area that I could get in touch with who could take a look or try pointing me in the right direction???
  2. Re: A3 2.0tdi cff keeps cutting out
    1840 Post(s)
    It needs a better diagnostic system trying which is VAG specific such as VCDS.
  3. Re: A3 2.0tdi cff keeps cutting out
    Jan 2024
    Cornwall
    Did you manage to find the cause of the car cutting out
  4. Re: A3 2.0tdi cff keeps cutting out
    Mar 2010
    Derry ireland
    60 Post(s)
    engine code would help or reg no
  1. 3.0tdi no power to injectors, no fault code then injector disconnected A6/C6 3.0TDI
    By Martynas26 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-08-2018, 09:53 PM
  2. Brakes and hub differences 2.0tdi and 3.0tdi
    By crazy4alfa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-08-2014, 11:03 AM
  3. 2006 a4 2.0tdi 140 cutting out?
    By tdigolf in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-12-2012, 04:16 PM
  4. Please Help 3.0tdi cutting out
    By ifty in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2008, 10:31 PM
