Thread: Audi A6 saloon 3.0tdi quattro 272hp
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. Re: Audi A6 saloon 3.0tdi quattro 272hp
    #21
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Can you post a total vehicle scan please? Sometime odd stuff happens in other modules, just need to rule that out. Ross-Tech won't answer any questions without a full scan for this reason - a classic example, is a faulty wheel speed sensor will light up the dashboard like a Christmas tree, and log fault codes in loads of different modules!
    Obviously cut out personal details from the scan like reg. no. and VIN no.
    Have you any scans form when this first happened, with the other faults?
  2. Re: Audi A6 saloon 3.0tdi quattro 272hp
    #22
    Mar 2017
    Hi. My vag com is russian made. Its exact same Ross Tech just in Russian language so will write all codes it comes up with after total scan.
  3. Re: Audi A6 saloon 3.0tdi quattro 272hp
    #23
    Mar 2017
    Anyway scanned car and found 2 fault codes. One is in the engine controle module P0675 00 [237] cylinder 5 glow plug electric circuit fault
    Second fault code is in Module 5F, MMI unit,fault code is B1564 01[009]. Funny why it explains fault as mass air meter 1. Air mass flow too high. Strange.
    Scanner i am using is genuine bit of kit that a lot of indy garages who work with VAG group cars use. Its same as Ross Tech with all features and you can do everything that a Ross Tech can. It is regestered and can be updated and is for unlimited vin's.
    Would be interesting to see it tested by somebody who knows and owns real ross tech scanner to see if my bit of kit does the job.
  4. Re: Audi A6 saloon 3.0tdi quattro 272hp
    #24
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    I don't understand this, the first code seems to be a generic OBD-II code, not a Audi specific code, but that only shows there is a fault somewhere from the control module and the glow plug inclusive. The second one makes no sense whatsoever. The MMI should never report an engine specific code, especially as the engine isn't reporting it as well!
    I suspect your scan tool isn't working properly, or something is being badly lost in translation.
  5. Re: Audi A6 saloon 3.0tdi quattro 272hp
    #25
    Mar 2017
    Hi. Worked out mmi code,its something to do with antenna,but ecerything works as it should.
    Glow plug fault code is correct though,isnt it?
  6. Re: Audi A6 saloon 3.0tdi quattro 272hp
    #26
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Glow plug circuit fault code is plausible, but it doesn't say what is faulty, could be the glow plug, wiring or controller.
  1. Please Help Buying the proper 3.0 TDI Quattro. Dilemma between 3.0 TDI 272hp vs 3.0 BiTdi 320hp
    By ThomasFFX in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 14-11-2019, 12:06 AM
  2. Question AUDI A6 Saloon 2.0TDI SE Saloon 1968cc CVT GEARBOX
    By VIPUL in forum Chat - Anything with wheels
    Last Post: 29-07-2016, 11:46 PM
  3. 2.0TDI 190 Quattro Saloon - September!?
    By ChrisGlasgow in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 15-07-2016, 02:30 PM
  4. Please Help Audi A6 Saloon, 2007 3.0TDi Tiptronic Le Mans
    By MrACD in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-05-2016, 08:58 AM
  5. 2016 2nd Gen Audi Q7 272HP MPG
    By Skippy73 in forum Q7 - 4M Forum - 2016 -
    Last Post: 18-02-2016, 03:51 PM
