Thread: Cambelt and water pump change?
  1. Cambelt and water pump change?
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All,
    I have a 2014 VW Golf MK7 1.6 TDI with the CLHB engine (I think that's right)
    I understand after 5 years the cambelt should be changed, I have a couple of questions:
    How hard is it to do? (do you need any special tools)?
    Do you change the water pump at the same time?
    Thanks in advance
  2. Re: Cambelt and water pump change?
    1836 Post(s)
    You need the old cam pin lock but a new design crank lock. It is not a bad job, just time consuming.
  3. Re: Cambelt and water pump change?
    Jan 2009
    Nuneaton England
    6 Post(s)
    Having done the 1.9TDI in the past is there much different?
    Would you have a procedure to do it?
    How does the new crank lock work/look?
    Again many thanks Crasher
  4. Re: Cambelt and water pump change?
    1836 Post(s)
    VEP or PD TDI?
  5. Re: Cambelt and water pump change?
    Jan 2009
    Nuneaton England
    6 Post(s)
    VEP or PD TDI?
    PDTDI cheers
  6. Re: Cambelt and water pump change?
    1836 Post(s)
    In some way it is like a cross between a VEP and PD TDI as you have a seperate pump which although it does not have to be timed and the Commencement Of Injection set it still has to be pinned to facilitate the correct belt tension. The kit I would recommend is Laser Tools 6809 Engine Timing Tool Set - for VAG 1.4, 1.6, 2.0i TDi CR but this does not include the very important counter hold tool equivalent to the VW T10172 Laser Tools 7279 Pulley Holding Tool Set - for VAG. If you do the job yourself, private message me your email and next week I will mail the instructions. It is worth knowing that with the main pulley oil can be seen spraying from the seal holder and if left it can damage the new belt. To deal with this you have to remove the toothed belt pulley so you can replace the end cover with a modified part, the seal running surfaces must be done dry and free of grease. To remove the pulley bolt (which MUST be replaced) you need another locking tool, 3415 and the new bolt is torqued to 180Nm plus 135 degrees... i.e. F tight!
  7. Re: Cambelt and water pump change?
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi Crasher,
    Tools have been ordered and I have sent you PM
  1. Cambelt and Water Pump change
    By sapstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-09-2016, 05:39 PM
  2. Cambelt and Water pump change.
    By neilos100 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-01-2013, 07:52 PM
  3. sharan cambelt and water pump change
    By robb in forum Touran - Sharan - Caravelle
    Last Post: 05-02-2009, 07:28 PM
  4. New Cambelt - change water pump?
    By RichieG in forum Golf MK5 - 2004 - 2009
    Last Post: 12-04-2008, 12:31 PM
  5. After cambelt and water pump change
    By shazzies in forum TT - 8N Forum - 1998 - 2006
    Last Post: 02-02-2007, 07:24 PM
