Thread: Golf Mk7 66 Plate Rear Door Leak
  1. Golf Mk7 66 Plate Rear Door Leak
    Aug 2015
    Cambridgeshire
    Hi guys,
    Water pools on the rear door seals of my wife's car along the sill. It's not enough to leak through but when I open the door, some of it runs into the foot well.
    A few Google search results suggest it's the door speaker seals and there is now a fix available, however the dealership are being less then helpful because it is out of warranty and want to first charge for a diagnostics before they will investigate the water issue.
    Does anyone have experience with this and what the fix involves?
  2. Re: Golf Mk7 66 Plate Rear Door Leak
    Aug 2015
    Cambridgeshire
    Update:
    I removed the door cards and was going to spray the door to see if I can identify the leak, but there was an obvious water stain running directly from the underside of each speaker.
    Annoyingly both speakers are cracked around the mounting rim so I called VW and they want 37 ea. I didn't think this was too bad however, installing them would tricky with the rivets because there is no way to evenly apply the force to compress the seal at all 4 fixing holes, so I'd probably end up breaking the new ones.
    With the speakers removed and all holes temporarily sealed, I've designed a ring that I'll 3D print and glue onto the back of the speaker to strengthen the rim. I'll get some photos and report back on the outcome should anyone be having the same issue.
  3. Re: Golf Mk7 66 Plate Rear Door Leak
    41 Post(s)
    968 Post(s)
    Yes a very common issue on 4 door Golf 7’s. At the beginning of lockdown I had to recover a dead Golf 7 owned by a doctor who had been volunteering abroad and had come back to get stuck in here. The car was covered in mould all over the inside and the rear floors full of water, condensation had got into the relay panel behind the glovebox and shut down the main power relay killing just about everything.
    If you care about the future of the planet, read this and watch the video
    https://www.bosch.com/stories/synthetic-fuels
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  4. Re: Golf Mk7 66 Plate Rear Door Leak
    Aug 2015
    Cambridgeshire
    Thanks for the information.
    Do you know how the leak was repaired?
  5. Re: Golf Mk7 66 Plate Rear Door Leak
    41 Post(s)
    968 Post(s)
    I haven't done it yet, he came back for an MOT but does not seem concerned about the mouldy swimming pool in the back. I see it every day as he lives around the corner.
  1. Golf Mk5 53 plate 1.9 TDI boost leak again!?
    By hussnainh8 in forum Golf MK5 - 2004 - 2009
    Last Post: 18-11-2016, 06:55 PM
  2. 53 plate A3 2.0 TDI sport rear bumper and O/S/F door card
    By Ben Tucker in forum Parts & Accessory Price Requests
    Last Post: 27-07-2015, 05:16 PM
  3. water leak rear passenger door!!!!!!
    By eduardo1180 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-07-2011, 12:14 AM
  4. 02 Plate 130 TDI Estate Rear Door Locks
    By swiggs01 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-10-2009, 05:01 PM
  5. 53 plate caddy van rear door problem
    By stormtrooper in forum The Commercial Range
    Last Post: 14-07-2007, 02:49 PM
