Thread: A6 AMI Retrofit
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: A6 AMI Retrofit
    #11
    Sep 2020
    South Wales
    Hi all, I have an A6 facelift with MMI 3G basic
    have the dvd player with SD card slots and a 6 cd changer.
    what are my options for retrofitting AMI ? Or A2DP bluetooth? Car has bluetooth for calls, but obviously isnt for streaming music.
    cheers
  2. Re: A6 AMI Retrofit
    #12
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by Veeb2k View Post
    cheers
    If you have MMI 3G, it's the same AMI harness kit regardless of whether you have the low or high version. So you just need the harness cable and some coding of the 5F module.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Re: A6 AMI Retrofit
    #13
    Sep 2020
    South Wales
    Fantastic,
    seen the link for the kufatec harness, plus they do the shroud. Already own VCDS, so will get that done!
    the harness goes into back of the DVD / SD drive?
    cheers
  4. Re: A6 AMI Retrofit
    #14
    May 2009
    69 Post(s)
    Fantastic,
    cheers
    The DVD/SD unit is the 5F multimedia module, and yes, this is where the harness plugs into. Check with Kufatec when you order that it is the right harness for your car. I'm 99% sure they are all the same for all MMI 3G cars (A4, A5, A6, Q7, A8) but it's worth double-checking.
    Cheers!
    MF.
  5. Re: A6 AMI Retrofit
    #15
    Jul 2013
    76 Post(s)
    If it only for music then this maybe a better option as it is cheap (worth a try i think).
    AMI MDI MMI Bluetooth Music Interface AUX Audio Cable Adapter Fit For Audi VW 3G | eBay
    I have the Ami retrofitted in my car and i never use it anymore. It was connected to an Ipod mini that gave up on me never used since.
    Dan
    2009/2010 2.0 TDIe SE
  6. Re: A6 AMI Retrofit
    #16
    Nov 2009
    bristol
    10 Post(s)
    Morning Folks
    I have fitted the audi harness to the rear of the the multi media module (5F)
    Can some one please tell me what coding has to be done in vcds to enable the ami ??
  7. Re: A6 AMI Retrofit
    #17
    Nov 2009
    bristol
    10 Post(s)
    Sorted
    Enabled ami via the hidden menu.
    All working
  8. Re: A6 AMI Retrofit
    #18
    Jul 2013
    76 Post(s)
    follow the link below and at step 7 check the AMI box. you dont need the aux in option.
    Activating AUX input on Audi MMI 3G and MMI MIB1 | Integrated automotive UK
    Also do this:
    in the hidden green menu.
    Select DIAGNOSTICS
    Select SETTINGS
    Select AMI / AUX
    Adjust the value of [AUX / no AMI BT / no AMI] on [AUX / no AMI BT / AMI] 7/8
    After this perform a MMI Reset.
    Dan
  9. Re: A6 AMI Retrofit
    #19
    Nov 2009
    bristol
    10 Post(s)
    Cheers Dan
    Also did oil level and battery status.
    Battry time soon as not been turning over asgood since cold snap
  1. Retrofit tow bar
    By Qseven in forum Q7 - 4M Forum - 2016 -
    Last Post: 31-08-2016, 09:02 PM
  2. Retrofit tv D3
    By simyboye in forum A8 - S8 - V8
    Last Post: 18-09-2013, 09:34 PM
  3. MDI Retrofit
    By CocoPops in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-06-2011, 02:49 PM
  4. Question 3G MMI Retrofit
    By Ilan in forum In Car Entertainment
    Last Post: 28-01-2011, 05:45 AM
