Thread: A6 AMI Retrofit
Results 1 to 10 of 19
  1. A6 AMI Retrofit
    bristol
    10 Post(s)
    Afternoon all
    My A6 has all the bells / whistles inc 10gb jukebox, sd card slots and 6 disc changer ( Bose system ) plays dvds also
    Would adding AMI be a pain ? I would like to use my 120gb ipod my missus bought me late last year.
    Thanks and apologies if this has been covered
  2. Re: A6 AMI Retrofit
    Nov 2020
    Oldemarkt, the Netherlands
    Audi Music Interface (AMI) Retrofit for A6 4F – Audi A6 Retrofit Blog
    This was the information I found. It seems pretty simple however I run in to a component protection/ ami update issue. After trying several hours to fix this problem I've installed a kufatec module for bluetooth.
  3. Re: A6 AMI Retrofit
    Nov 2020
    For the above reason I have my AMI for sale on ebay.
    Audi Music Interface AMI 4E0 035 785 D | eBay
  4. Re: A6 AMI Retrofit
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by quattrogary View Post
    Afternoon all
    You mention having a 10Gb jukebox, so I assume you have a facelift car with MMI 3G High (with the "top hat" joystick on the MMI knob)? Many of these came with AMI already installed. It isn't a unit per se - just a harness and coding. One end of the harness connects into the back of the 5F multimedia unit in the glovebox, and the other end (where you plug in your AMI cable) is usually sited in the roof of the glovebox. It's worth looking to see if you already have it - the AMI connection is hidden away almost invisible in the roof of the glovebox and it's easy to miss it.
    It's a very easy retrofit if you don't already have it.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  5. Re: A6 AMI Retrofit
    bristol
    10 Post(s)
    Thanks for the reply.
    I know where it should be, but just an empty hole in the roof of the glove box.yes i have the facelift withe the joystick. 3g high. Please let me know what i need?
    Thank you
  6. Re: A6 AMI Retrofit
    Jul 2013
    78 Post(s)
    If you have the hole then it would have been installed before. if it was not there before the cut out would be there for you to push out.
    Drop the glovebox to see if the cable has fallen out.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  7. Re: A6 AMI Retrofit
    bristol
    10 Post(s)
    Will double check and get back to you. Maybe there is no hole.
    Thank you
  8. Re: A6 AMI Retrofit
    May 2009
    69 Post(s)
    Thank you
    You will need the AMI 3G harness cable set, and you will need to code the 5F module to tell it AMI is installed - someone with VCDS should be able to help do this.
    The cable set is available from Kufatec https://www.kufatec.com/en/car-hifi/...r-mmi-3g-36735
    You can also probably find them for less on Ebay.
    Cheers!
    MF.
  9. Re: A6 AMI Retrofit
    bristol
    10 Post(s)
    I can see the hole where it should be. Would it be cheaper to retrofit bluetooth??
    Any cheaper options with the Ami cable?
  10. Re: A6 AMI Retrofit
    May 2009
    69 Post(s)
    If you have the hole already, it sounds like AMI was previously installed. As Dan suggested, the cable may simply have fallen out. Take the glovebox down to check if the cable is there before you do anything else.
    Cheers!
    MF.
  1. Retrofit tow bar
    By Qseven in forum Q7 - 4M Forum - 2016 -
    Last Post: 31-08-2016, 09:02 PM
  2. Retrofit tv D3
    By simyboye in forum A8 - S8 - V8
    Last Post: 18-09-2013, 09:34 PM
  3. MDI Retrofit
    By CocoPops in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-06-2011, 02:49 PM
  4. Question 3G MMI Retrofit
    By Ilan in forum In Car Entertainment
    Last Post: 28-01-2011, 05:45 AM
