Thread: Knocking now driving me crazy
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 60
  1. Re: Knocking now driving me crazy
    1840 Post(s)
    I have had a lot of these ZF EPAS steering gears knock and found it to be the inner mounting of the track rod, the “drum stick” in parts counter speak a tiny almost imperceptible amount of wear makes a terrible noise. When they are worn they have quite a characteristic rattle, no so much a regular knock knock but a rapid rattle reacting to the road surface. A few weeks ago we had a chap with a Golf 5 (PQ35 is virtually identical to PQ46) who was being driven mad with a rattle and he had replaced everything and it was a terrible noise but I could not find it, with someone in the car on the lift, rocking the steering showed the right lower drop link was nut was loose as someone had reused the old nut. Quite often I have seen people unwittingly cure a noise and at the same time introduce one.
  2. Re: Knocking now driving me crazy
    Dec 2016
    lincoln
    24 Post(s)
    Thanks for the info Crasher. Have 2 new inner tie rods now so going to replace them. That is always a possibility as I have now had the whole lot apart a few times replacing everything lol. When I do the inner tie rods I will go through everything again checking for correct fitment.
    Current Vehicles
    Passat B6 Estate 170PD (Bluefin Installed 200BHP) BMR Highline
    Aprilia RSV 1000 Factory
  3. Re: Knocking now driving me crazy
    Dec 2016
    lincoln
    24 Post(s)
    Right both inner tie rods replaced. Fitted new subframe bolts with the spacers. All engine mounts done. Shock horror car still knocking. I can only think maybe one of the new parts was not up to standard when I fitted it. Have been round everything and with load on and off can not find a single thing loose. Beyond belief really lol. Nothing left to change now on the front of the car.
    Current Vehicles
  4. Re: Knocking now driving me crazy
    Nov 2019
    united kingdom
    Quote Originally Posted by Marshall1975 View Post
    I feel your pain. Right now I'm chasing a frustrating knocking noise and am replacing parts with no luck. Inspecting the car on jack's, everything feels solid until it's rolling on the road.
    Sent from my ONEPLUS A5000 using Tapatalk
  5. Re: Knocking now driving me crazy
    Dec 2016
    lincoln
    24 Post(s)
    Lol I am genuinely without ideas now. When I say everything on the front has been replaced I'm not joking. Well I tell a lie I have not done the drive shafts but I'm confident the knocking i'm hearing is not a drive shaft.
    Current Vehicles
  6. Re: Knocking now driving me crazy
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Did you do the dog bone gearbox to subframe mount as well?
    Test the steering with the steering lock and engine off as any steering wear is amplified without power assistance - turn moderately side to side and if you get audible knocking...
    Mad Mitch
  7. Re: Knocking now driving me crazy
    #17
    Dec 2016
    lincoln
    24 Post(s)
    Funny you should ask Mitch. I certainly did as came off easy but my god trying to get the holes lined up when putting back on is epic lol. I will try the steering in the morning and see what I can find. Thanks mate.
    Current Vehicles
  8. Re: Knocking now driving me crazy
    #18
    1840 Post(s)
    Top of my suspect lift for new parts or their fitting causing a pattering rattle would be the ARB drop links.
  9. Re: Knocking now driving me crazy
    #19
    Jan 2012
    10 Post(s)
    87 Post(s)
    What is the knocking like?
    Definite knock or more of a rattle?
    Do you hear it generally, on certain surfaces or other times?
    When travelling straight, turning or both?
    Pinch bolts tight on struts?
    Bearings checked?
    Inner OS CV joint boot protector cover on correctly / tightly?
    Disc back guards not contacting anything?
    Springs are not moving when turning?
    Steering COLUMN tight including flexible union?
    Its going to be something silly like a loose bolt, something not fully in or something at the back of the engine hasn't got enough clearance - my new DPF took several adjustments to stop it contacting the EGR cooler pipe connection. Horrible rattle as it vibrated against the flange.
    Mad Mitch
  10. Re: Knocking now driving me crazy
    #20
    Nov 2019
    united kingdom
    Quote Originally Posted by DMitch16 View Post
    Not trying to hijack this thread, is this the test you meant? Power steering is off, unsure if this noise is normal. https://cloud.tapatalk.com/s/5f4ae9c4...9_192410_1.mp4
  1. Please Help No hot air driving me crazy lol
    By Audi8ls3 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-02-2017, 11:43 AM
  2. Question A3 Self-locking driving me crazy
    By Casanunder in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-01-2013, 11:54 AM
  3. Please Help Mk4 Golf Front knocking is driving me crazy !!!
    By MagicMat in forum Golf MK4 - 1999 - 2004
    Last Post: 17-05-2012, 07:30 AM
  4. Please Help My passat is driving me CRAZY
    By Kopitekid1960 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2009, 11:16 AM
  5. Crazy Arabs Driving
    Last Post: 19-03-2007, 04:57 PM
