Thread: P2108 Error Code - Dirty Throttle Body Adapter?
Results 1 to 10 of 19
  1. P2108 Error Code - Dirty Throttle Body Adapter?
    Oct 2009
    yorks england
    Hi All
    Quick summary of the problem - I've just had an engine light error which is giving me an error code P2108 "Throttle Actuator Control Module Performance". I first had it 2 weeks ago, cleared it and it came back yesterday. I've been doing a lot of city driving recently (Stop/Start, low speeds) - don't know if relevant or not. To give a bit of history, 12 months ago I had the Throttle Body replaced as it malfunctioned. Been perfect since. I'm now wondering if a dirty Throttle Body Adapter could cause the new error, however I am far from a car expert and could be completely wrong.
    My questions are:
    Is it likely to be that? If not, what is more likely?
    If it is the TBA, is it complicated removing and cleaning?
    Is this serious/urgent? We leave on holidays in 2 days (700km each way in a week, mostly motorways) so would like to know if this needs to be sorted before we go or if it's something that will be OK for that distance/time.
    It's a late 2005 3.0 TDI with about 100,000 miles. No noticeable performance issues. Changed all the injectors 18 months ago.
    Thanks very much for any input.
    NB
  2. Re: P2108 Error Code - Dirty Throttle Body Adapter?
    1840 Post(s)
    Do you know any details of what was replaced? The code P2108 doesn't sound right to me, more a generic code a cheap code reader throws out to confuse people. I would start with a VAG specific code read using VCDS.
  3. Re: P2108 Error Code - Dirty Throttle Body Adapter?
    Oct 2009
    yorks england
    The throttle body was replaced last summer.
    Yes it is just a cheap code reader but when I have to pay €150 for the garage to plug it in each time I'd ideally like to avoid going down that route.
  4. Re: P2108 Error Code - Dirty Throttle Body Adapter?
    1840 Post(s)
    Unless you get a proper code read done you could replace the wrong part, it could be the manifold flaps.
  5. Re: P2108 Error Code - Dirty Throttle Body Adapter?
    Oct 2009
    yorks england
    OK but if I do try to clean out the Throttle Body Adapter, is that a big job and what is my downside? If it fixes it, great, if not no harm done?
  6. Re: P2108 Error Code - Dirty Throttle Body Adapter?
    1840 Post(s)
    It is on the cars left of the engine with a flexible hose coming from the left intercooler and is mounted to an adapter which bolts to the inlet manifold distribution pipe. A gentle wipe inside with solvent is OK BUT make sure no solvent gets into the manifold, it is much safer to remove the motor.
  7. Re: P2108 Error Code - Dirty Throttle Body Adapter?
    Jul 2008
    Lisburn
    15 Post(s)
    Crasher is right cant beat VCDS, however it is expensive to keep in the glove box (metaphorically speaking ) just in case.
    However OBD eleven is licensed by VAG and is worth its money (about the same as a scan by a garage) when it comes to debugging at this level.
    It does have its pitfalls if you try and use it like VCDS, but i believe its a good tool for the one car, have a go owner.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
    1 1 0
  8. Re: P2108 Error Code - Dirty Throttle Body Adapter?
    1840 Post(s)
    I did have a quick play with OBD11 on a customers car but didn't have time to dig deeper.
  9. Re: P2108 Error Code - Dirty Throttle Body Adapter?
    Oct 2009
    yorks england
    Sorry - don't understand this bit.
    I saw a guy on this forum took his TBA right off and cleaned it properly - it just didn't go into detail as to how to do this and how tricky (or not) it was. His was filthy - almost completely blocked up. I wonder if mine has a similar problem.
    By the way, thanks for your time on this.
  10. Re: P2108 Error Code - Dirty Throttle Body Adapter?
    Oct 2009
    yorks england
    Mine is an OBD11
  1. Aui A8 Throttle Body Error Codes
    By A8pete in forum A8 - S8 - V8
    Last Post: 26-07-2018, 01:01 PM
  2. Question THROTTLE BODY adaption error AHW engine
    By sharanthing1 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-04-2015, 06:12 PM
  3. Engine Mgt Light on, Error Code p0006 Throttle Body.......
    By mattredaudia6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-11-2013, 08:28 PM
  4. Throttle body, just dirty or broken.
    By Team Green in forum Polo - Derby - Lupo - Fox
    Last Post: 11-08-2011, 02:16 PM
  5. Please Help Error code P2108
    By pritz25 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-09-2009, 04:08 PM
