Thread: Air con learnings
Results 1 to 10 of 16
  1. Air con learnings
    Nov 2013
    west midlands
    Hi there trying to investigate the air con on my 2007 golf just wondered it anyone has any help to try and narrow down the issue
    Firstly noticed the compressor seems to run all the time even with air con off is this normal
    Pressures fine but no cooling or the pipes anywhere
    Fans do not run under the bonnet
    Any tests I can do to try and narrow down the issues. I do have vagcom thanks
  2. Re: Air con learnings
    1840 Post(s)
    It is a constant drive modulated delivery compressor so always APPEARS to be working. If there are no low pressure codes coming up from a scan of the HVAC then it is almost certain that the compressor valve has failed and the easiest cure is a new Denso compressor... on the Golf 5, 6 and 7 (basically all PQ35 and MQB platform vehicles) this is a VERY common problem.
  3. Re: Air con learnings
    Nov 2013
    west midlands
    Thanks no tests I can do with vagcom to kick start it ?
  4. Re: Air con learnings
    Nov 2013
    west midlands
    Just a quick update
    Scanned vagcom comes up with this
    This fault keeps coming back
    Did a test on the solenoid and it seems to be doing something
    I then checked engine faults and it came up with this. I was trying to get the air con working when the car had done 200 miles so was very hot
    This fault has cleared
    I have tested the fan and that works
    In measuring there’s no working from the compressor and the fridge pressure just has a - by it and no number there is gas in there as I’ve checked
    What you reckon don’t mind throwing a bit of money at all but not tonnes
  5. Re: Air con learnings
    1840 Post(s)
    New switch, a VERY common failure and then a gas pressure check.
  6. Re: Air con learnings
    Nov 2013
    west midlands
    Does anyone know the part number for the 0 ring seem to end up with loads of different numbers
  7. Re: Air con learnings
    Nov 2013
    west midlands
    I checked the air con pressure this morning and it seems to have lost about 5psi overnight
    When trying to get the connector off the high pressure sensor I could hear a hiss so I’m hoping it’s that
  8. Re: Air con learnings
    1840 Post(s)
    The sensors (switch as I said but that is the wrong description) are very prone to leaking.
  9. Re: Air con learnings
    Nov 2013
    west midlands
    Thanks I have replaced the switch
    The fault code has gone but has been replaced with refrigerant low which is understandable
    I can now see all the readings in vagcom where before it just showed dashes
    I did check the fuse and power to the connector before I replaced
    Went to the shop for a pressure test and regas and there gas run out so it’s for another day
  10. Re: Air con learnings
    1840 Post(s)
    I had that last week, desperately trying to get a chaps AC working to go on holiday and the vacuum pump failed...
