Thread: Right Engine Mount Solenoid Valve
Results 1 to 8 of 8
  1. Right Engine Mount Solenoid Valve
    Dec 2013
    Liverpool
    10 Post(s)
    What does this do and could this cause a knock when driving over un even surfaces???
    1 Fault Found:
    005495 - Right Engine Mount Solenoid Valve (N145)
    P1577 - 001 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 254
    Reset counter: 255
    Mileage: 226051 km
    Time Indication: 0
    Date: 2020.04.10
    Time: 14:35:13
    2007 2.7 SE quattro saloon
  2. Re: Right Engine Mount Solenoid Valve
    1837 Post(s)
    Never known one to cause a knock there are plenty of other parts up that end which knock.
  3. Re: Right Engine Mount Solenoid Valve
    Dec 2013
    Liverpool
    10 Post(s)
    Are upper control arms a common failure? Stabiliser links have been replaced.
  4. Re: Right Engine Mount Solenoid Valve
    bristol
    10 Post(s)
    If memory serves this is an electro hydraulic mount. Did one on my A6 2.7tdi quattro. Makes the engine vibrations dissapear to give a smoother ride / no engine vibration. Found a valeo replacement online for less than £60.
  5. Re: Right Engine Mount Solenoid Valve
    1837 Post(s)
    Upper and lower link wear is a common problem and for the upper, getting the retaining bolt out can be a nasty job.
  6. Re: Right Engine Mount Solenoid Valve
    Dec 2013
    Liverpool
    10 Post(s)
    Can anyone shed any more light on this part (part number) and whether it is the off side (drivers side) or near side (passenger side) and how difficult it is to change?
    Quote Originally Posted by peter goble View Post
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Reset counter: 255
    Mileage: 226051 km
    Time Indication: 0
    Date: 2020.04.10
    Time: 14:35:13
  7. Re: Right Engine Mount Solenoid Valve
    bristol
    10 Post(s)
    Had this on my 2.7tdi a6
    Its an electrohydraulic mount instead of the old rubber type. A current passes through the mount to change the dampening action.
    I found a quality valeo replacement on ebay at a fraction of audi prices.
  8. Re: Right Engine Mount Solenoid Valve
    1837 Post(s)
    The handing of a part is always viewed as sitting in the car looking forwards and does not change by your point of observation, right is right as left is left as front is... well you get the ides.
  1. Right engine mount solenoid valve N145
    By 54A4Avant in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-11-2017, 04:55 PM
  2. Engine Mount Solenoid Valve
    By papadelta in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-06-2017, 04:53 PM
  3. Replies: 2
    Last Post: 23-05-2017, 09:26 PM
  4. engine mount solenoid valve?
    By markoA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-12-2013, 05:10 PM
  5. Please Help Mount solenoid valve
    By AUDI44 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-12-2013, 09:03 PM
