Thread: Non sports coil springs fitted, when it should have them, should I care?
  1. Non sports coil springs fitted, when it should have them, should I care?
    May 2013
    required field
    Hi all,
    I have a Golf GT 160 from 2012 which has been really well looked after and I've enjoyed very much. I stopped taking it to the VW dealer for servicing a couple of years ago because they were awful and expensive (Arnold Clark) and found a good "ordinary" reliable and cheap local garage. They've been really good, and are handy.
    I put it in for an overdue (due to covid) service last week, and they discovered 3 broken springs - none of which I'd noticed... When they phoned to tell me this, I told them that this model had the slightly lowered sports suspension, and were they sure they were ordering the right springs? He said they just put in the registration plate and it tells them what to order... which made me nervous straight away.
    Anyway its back, and it seems fine, and at least it would pass an MOT now, but I spotted the part number on a front spring - SUPLEX 39202. After a bit of investigation, I'm certain this is the standard spring from the 80PS car. I found the Suplex catalogue online. The one I should have looks like the SUPLEX 39332
    Most people would never notice, and I'm sure it will be fine to drive, and I'm not sure I'll notice any difference. Car is only worth about 4k now, but its irritating me. What would you do?
    I was about to buy a newer GTi back in March to replace it, but have put that on hold for various covid-related reasons, so I suppose I might have the car for a while now.
    - Rob
  2. Re: Non sports coil springs fitted, when it should have them, should I care?
    41 Post(s)
    967 Post(s)
    I also need the reg to check but I use the VIN to ascertain the spring using ETKA FI Suggestion and the cars build PR codes to give me the VW OE number and then use Tec Doc to cross reference, direct reg look up is risky. The only aftermarket springs I will fit are Suplex but the supply is erratic with the new UK distributor. The Suplex number cross references to a VW 1k0 411 105 AJ which fits a lot of PQ35 platform VW, Audi and Skoda's but not any Seats. It is marked 1 x blue, 1x orange and 1x green OR 1 x grey and 3 x white and is for cars with PR-2UA+L01 suspension which is standard suspension for the lightest front axle weight of 621>650kg, i.e. completely wrong.
    If you care about the future of the planet, read this and watch the video
    https://www.bosch.com/stories/synthetic-fuels
  3. Re: Non sports coil springs fitted, when it should have them, should I care?
    May 2013
    required field
    I'm going to DM you and politely ask if you can look mine up to confirm please! Then I'm going to ask them to fit the correct ones.
    I've just driven it to the Highlands of Scotland on roads I'm familiar with, it feels ok, it feels safe, but definitely not as firm and planted as it was.
  4. Re: Non sports coil springs fitted, when it should have them, should I care?
    41 Post(s)
    967 Post(s)
    Remind me tomorrow, it is easier at work on a PC than an iPad.
  5. Re: Non sports coil springs fitted, when it should have them, should I care?
    41 Post(s)
    967 Post(s)
    Oh God, a CAVD engine... you have my sympathies. The front springs are OE 1K0 411 105 AT (Suplex 39332) at 108.37 inc VAT and the rears are 1K0 511 115 GC at 90.31 inc and Suplex do not list this spring.
  6. Re: Non sports coil springs fitted, when it should have them, should I care?
    May 2013
    required field
    Thanks very much for your reply, its appreciated.
    I'm going to get them to fix the car properly, and then I'm going to try to sell it privately, and then buy a 2016/17 Golf GTI- I presume the engine in these is less traumatic for you guys? It'll go to a main vw dealer initially, then a vw specialist, I've learned my lesson.
    For information, for anyone else reading this, the car felt fairly hopeless on twisty mountain roads - compared to how it used to be. However around town you couldn't tell the wrong springs were fitted.
  7. Re: Non sports coil springs fitted, when it should have them, should I care?
    41 Post(s)
    967 Post(s)
    The third generation EA888 used in the Golf 7 GTI is looking like a reliable unit and the oil consumption seems OK as well... just serviced one in an S3.
  8. Re: Non sports coil springs fitted, when it should have them, should I care?
    May 2013
    required field
    I took my car back to the garage that fitted the springs, and they have now fitted the correct genuine VW parts (they said they couldn't get the alternate Suplex ones just now).
    Car drives significantly better than before - feels solid and secure on the road again. Don't put up with the wrong springs people!
  9. Re: Non sports coil springs fitted, when it should have them, should I care?
    41 Post(s)
    967 Post(s)
    Yes sourcing Suplex in the UK is an issue at the moment but if you have the time you can order them from Germany, I am just doing that for an A5 to send them to Malaysia together with new dampers, arm kit etc.
  1. i need new coil springs
    By johnro79 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 12-08-2020, 03:33 AM
  2. Question Coil springs
    By maccaone in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 28-07-2015, 03:29 PM
  3. Question 1.9 tdi coil springs
    By switchblade in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2011, 06:30 PM
  4. coil springs
    By shaunebabe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-11-2008, 08:13 PM
  5. coil springs
    By panther in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-05-2007, 06:10 PM
