Thread: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
  1. Re: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
    #21
    1835 Post(s)
    With the engine running, disconnect the vacuum pipe to the fuel pressure regulator, be careful though as fuel may come out if it is what I suspect.
  2. Re: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
    #22
    Jul 2020
    Sweden
    I disconnected the pipe with the engine running and had it like that for about 12 minutes. There came no fuel and the little pipe from the regulator felt dry.
    Too bad it didn't leak fuel, it would have been such easy thing to replace to get the car back in order.
  3. Re: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
    #23
    1835 Post(s)
    Start the engine, go into basic settings 04 and into group 099 and see how it runs and drives plus see if you can get a Co test.
  4. Re: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
    #24
    Jul 2020
    Sweden
    It ran ok at first, but after parking and going to the store for 10 minutes it started
    to jerk/jump/hesitate a few times on the way back and there came a popping sound as well.
    While on idle and driving. Engine - Basic Settings 4 - Group 99.
    The bits were changing while driving and on idle.
    800 /min
    136.00 DegC
    -50%
    00010111
    2048 /min
    138.00 DegC
    -50%
    00000110
    1664 /min
    136.00 DegC
    -50%
    00000111
    1696 /min
    136.00 DegC
    -50%
    00001111
    1952 /min
    136.00 DegC
    -50%
    00010111
    2496 /min
    136.00 DegC
    -50%
    00010110
    800 /min
    141.00 DegC
    -50%
    10000010
    I'll look around if I can get a CO test somewhere.
    The test I mentioned before was done on 17 Dec.
    CO-/K: 2,2%
    HC: 999 ppm
    CO: High idle: 6,2%
    Lambda: High idle: 0,84
  5. Re: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
    #25
    1835 Post(s)
    If that value in Zone 2 is corrcet the engine is a touch hot, that is the coolant temperature as the ECU sees it... I have emailed you some info.
  6. Re: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
    #26
    Jul 2020
    Sweden
    Thanks for the mail, I'll have a read and see if I understand any
    I might go for a drive tomorrow and check the values again. It's been snowing heavily here and will probably continue, so I'll see how it looks tomorrow.
    Recently, a mechanic took a quick look at the car and the error codes. He said the exhaust manifold has gotten white from heat.
    He thinks the catalytic converter is clogged and has caused that heat.
    Would that theory fit with the coolant temperature being high and the other symptoms of the car?
    He also said there could be a problem with the lambda sensor.
  7. Re: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
    #27
    1835 Post(s)
    Cat failure is very rare, we replace very few... probably only a dozen in 20 years, whereas other garages replace that many a month. My immediate concern is that high engine temp reading, doesn’t make sense.
  8. Re: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
    #28
    Jul 2020
    Sweden
    I dug out my car today after some heavy snowing and drove it for 15 minutes and had it on idle also. Temp meter showed a steady 90.
    First I used the Xtool VAG401 while the car was getting up in temperature and the temp showed 130 and rising.
    Then I connected my old laptop, the battery lasted long enough to get a few readings with VCDS Lite.
    Since I don't have the registered version (used a friends laptop before) I couldn't get to 04 Basic Setting - Group 99.
    I used Measuring Block - Group 01 instead which also shows the coolant temperature.
    768 /min
    87 C
    0.64 V
    10000010
    768 /min
    93 C
    0.74 V
    10001010
    1760 /min
    93 C
    0.88 V
    10011010
    The highest it got to was 98 C.
    I then connected Xtool VAG401 again and it showed (Basic Settings - Group 99)
    800 /min
    148.00 DegC
    0.800 V
    10001010
    At first I was thinking maybe Xtool VAG401 showed the temperature in Fahrenheit, but 148 F is about 64 C.
    So it can't be that either.
    I can only guess that the Xtool shows wrong temperature for some reason. Or maybe it is some setting which I
    haven't found yet.
    Anyway, in Basic Settings Group 99 in status of Lambda, the first bit to the left show 1 often.
    From what I can find it means "Fault recorded in memory during diagnosis; interrogate fault memory"
    Is that a sign that the Lambda is faulty?
  9. Re: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
    #29
    1835 Post(s)
    What is the fault stored? Did you get the info I sent you?
  10. Re: Throttle body adaptation, Leon 2001 AKL 1.6 SR. Result correct?
    #30
    Jul 2020
    Sweden
    Yes, I got the info, thanks! I've been looking through it, lots of usefuel things. I can't say I understand everything though haha.
    It was in one of the files I read about the bits in basic settings - group 99 - zone 4.
    It said zone 4 is the operating status of lambda control and if the first bit to the left is a "1" then it signifies:
    memory =>Page 01-10.
    And it often shows a "1" there, not all the time though. The bits in zone 4 change quite often.
    I see now, that bit just indicate that there has been a fault code recorded. And I do have fault codes concerning Lambda.
    I thought first it meant the Lamda wasn't working.
    The fault codes I have stored are
    00537 - Lambda (Oxygen Sensor) Regulation: Lower Limit
    00525 - Oxygen (Lambda) Sensor (G39): Implausible Signal
  1. Replies: 7
    Last Post: 10-07-2013, 03:34 PM
  2. A4 B5 Throttle Body Adaptation
    By jonathanfenton in forum VCDS - General Questions
    Last Post: 24-10-2011, 07:57 AM
  3. polo 2001 1.0e throttle body alignment/rest
    By yas_b in forum Polo - Derby - Lupo - Fox
    Last Post: 14-08-2010, 09:27 PM
  4. Throttle Body Adaptation - An interesting fact
    By preb1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-01-2009, 10:04 AM
  5. Throttle body clean without adaptation
    By paddymm in forum VCDS - General Questions
    Last Post: 15-06-2008, 08:34 PM
