Thread: non starter after being left for two weeks
Results 1 to 10 of 19
  1. Angry non starter after being left for two weeks
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    2.0 tdi sline 2006 was running perfectly , car was left for two weeks and now wont start
    Code:
    VIN: WAUZZZ8P47A039226   License Plate: ABC1234Mileage: 219470km-136372mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 77 7D
    VIN: WAUZZZ8P47A039226   Mileage: 219470km-136372miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine        Labels: 03G-906-018-BMN.clb
       Part No SW: 03G 906 018 DN    HW: 03G 906 018 DN
       Component: R4 2.0l PPD1.2 G    1247
       Revision: --H22---    Serial number: AUX7Z0F6FNJ01J
       Coding: 0000072
       Shop #: WSC 66565 257 00032
       VCID: 74E7BAF5176ABCE1DB-8020
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
       Component: ESP FRONT MK60      0101
       Revision: 00H11001
       Coding: 0023170
       Shop #: WSC 06314 000 00000
       VCID: 73E5B9E91264BBD9C2-8026
    2 Faults Found:
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
                003 - Mechanical Failure - Intermittent
                008 - Implausible Signal - Intermittent
    Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
       Part No SW: 8P0 820 043 N    HW: 8P0 820 043 N
       Component: KlimavollautomatH18 0300
       Revision: 114439      Serial number: 8P0820043N
       VCID: 377D4DF9469C17F93E-8062
    2 Faults Found:
    01592 - Air Quality Sensor (G238)
                010 - Open or Short to Plus
                 Freeze Frame:
                        Fault Status: 01101010
                        Fault Priority: 3
                        Fault Frequency: 17
                        Reset counter: 21
                        Mileage: 218801 km
                        Time Indication: 0
                        Date: 2020.05.21
                        Time: 18:08:46
                 Freeze Frame:
                        Temperature: -50.0°C
    00483 - Control Module for Auxiliary Air Heater
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 151
                        Mileage: 218400 km
                        Time Indication: 0
                        Date: 2020.04.01
                        Time: 09:26:04
                 Freeze Frame:
                            ON
    Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
       Component: Bordnetz-SG     H43 1201
       Revision: 00H43000    Serial number: 00000006000401
       Coding: E4885F01B214100000160000160000000008FA175C0100
       Shop #: WSC 06314 000 08192
       VCID: 408F2625135250418F-8014
       Subsystem 1 - Part No: 8P2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H01 0130
       Coding: 00062736
       Shop #: WSC 06314
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0090
       Coding: 00150573
       Shop #: WSC 06314
    1 Fault Found:
    00988 - Lamp for Brake Light; Right (M10)
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 27
                        Mileage: 219455 km
                        Time Indication: 0
                        Date: 2020.07.12
                        Time: 11:19:00
                 Freeze Frame:
                            ON
                        Voltage: 14.20 V
                            ON
                            ON
                            OFF
                            OFF
                            ON
    Address 15: Airbags        Labels: 8P0-959-655-94.lbl
       Part No SW: 8P0 959 655 C    HW: 8P0 959 655 C
       Component:    Airbag 9.41  H12 3760
       Revision: 91H12376    Serial number: 003620G1AKGV
       Coding: 0071612
       VCID: 428B2C2D1D5E425199-8016
       Subsystem 1 - Serial number: 6332DRB4037DCAB40
       Subsystem 2 - Serial number: 6342DRB4037D89B2.
       Subsystem 3 - Serial number: 63528RB401701602/
       Subsystem 4 - Serial number: 63628RB4017010471
       Subsystem 5 - Serial number: 63729RB401733F22G
       Subsystem 6 - Serial number: 63829RB401733EDE
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H34 0070
       Coding: 0000022
       VCID: 418923211858594980-8014
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
       Part No SW: 8P0 920 951 D    HW: 8P0 920 951 D
       Component: KOMBIINSTR. VDO H18 0560
       Revision: D0H18002    Serial number: 1246F002001098
       Coding: 0004403
       Shop #: WSC 80093 222 69422
       VCID: 366340FD4196EEF125-8062
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Part No SW: 1K0 907 530 J    HW: 1K0 907 951
       Component: J533__Gateway   H12 0160
       Revision:   H12       Serial number: 320010662787F6
       Coding: 3D3F0BC207002103
       VCID: 2E53689DB9C6D6316D-807A
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Revision: D0H18002    Serial number: AUX7Z0F6FNJ01J
       Shop #: WSC 57285 003 1048576
    1 Fault Found:
    16346 - Control Module - ROM Error
                014 - Defective
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
       Part No: 8P0 959 801 H
       Component: Tuer-SG         020 0090
       Coding: 0000760
    Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.079 H07 1806
       Shop #: WSC 02069 000 90108
       VCID: 356147F15C90E5E92C-8060
    Address 46: Central Conv.        Labels: 8P0-959-433.lbl
       Part No: 8P0 959 433 C
       Component:    KSG          H04 0050
       Coding: 188000186D088505489FC63300
       VCID: 3C7752D57FBA34A1D3-8068
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 8P0 951 177
       Component: Innenraumueberw.H04 0020
    Address 47: Sound System        Labels: 8Px-035-382.lbl
       Part No SW: 8P4 035 382     HW: 8P4 035 382
       Component: AB2 SUBWOOFERBOXH04 0180
       Revision: 00003       Serial number: 30674526449165
       Shop #: WSC 00000 000 00000
       VCID: 71E9B3E1687889C930-8024
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
       Part No: 8P0 959 802 H
       Coding: 0000760
    Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
       Part No SW: 8P0 035 186 C    HW: 8P0 035 186 C
       Component: concert II EU   H52 0100
       Revision:      02S    Serial number: AUZ2Z3F4225280
       Coding: 0001021
       Shop #: WSC 06435 000 00000
       VCID: 326B7CEDADFEF2D109-8066
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No: 8P4 959 801 D
       Component: Tuer-SG         020 0070
       Coding: 0000216
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No: 8P4 959 802 D
       Coding: 0000216
    Address 77: Telephone        Labels: 8P0-862-335.lbl
       Part No SW: 8P0 862 335 H    HW: 8P0 862 335 H
       Component: FSE_255x BT     H21 0290
       Revision: 00000001    Serial number: 00000000504452
       Coding: 0000120
       VCID: 3B7551C97AB43399DA-806E
    Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
       Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
       Component: PTC-Element         0404
       Revision: 00800000    Serial number:
       VCID: 2D516F91B4C0AD2954-8078
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
                014 - Defective
    End-------------------------(Elapsed Time: 02:19)--------------------------
  2. Re: non starter after being left for two weeks
    Near Blackpool
    48 Post(s)
    You have your answer, your immobiliser has failed. Rom errors are terminal.
  3. Re: non starter after being left for two weeks
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    That 16346 error was there before , the cluster has already been to ecu testing for a repair earlier this year to try and cure the central locking not working as Audi main dealer said the cluster was faulty , ecu testing fixed it but I still had no central locking and that error was there but I assumed that I needed to get the keys recoded , the cluster has a lifetime warranty from ecu testing and It will now be collected by them for testing .
  4. Re: non starter after being left for two weeks
    Near Blackpool
    48 Post(s)
    Not much you can do till they fix the rom error on your cluster.
  5. Re: non starter after being left for two weeks
    1840 Post(s)
    Quote Originally Posted by stephenwhite990 View Post
    the cluster has already been to ecu testing for a repair earlier this year.
    Does the car start and then stop after a second? The cluster has nothing to do with the central locking, that is a separate box.
  6. Re: non starter after being left for two weeks
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    No it just turns over . Audi said that the imobiliser /cluster was stopping comms to the central locking unit
  7. Re: non starter after being left for two weeks
    1840 Post(s)
    If it was the immobilser the engine would start and stop and you would get a dash warning. There are a few things nagging me, one is the initial code read table of units says there is an engine malfunction but there is no code and there is not code on the convenience system which is the central locking and I don't know of any link between the immobilser and the central locking unless it is something hidden in the CAN BUS messages. If it just cranks over and does not start with no engine codes my first job would be to observe the cranking rpm in measuring blocks. This means cranking the engine over for a good 30 seconds as VCDS drops comms initially and it takes a few seconds to come back so the battery needs to be good to keep up.
  8. Re: non starter after being left for two weeks
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    I will have to wait till the cluster comes back now but I will put the battery on trickle untill then and see what happens when I get the cluster back
  9. Re: non starter after being left for two weeks
    Near Blackpool
    48 Post(s)
    Don’t think an ecu or cluster I’ve ever sent has come back working properly. I normally get one off a scrapper now and if VCDS can’t recode it I get a garage I know with the full dealer gear to guided fault find and replace which recodes it all magically through clouds.
  10. Re: non starter after being left for two weeks
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    One of the faults listed on your VCDS scan shows :-
    2 Faults Found:
    When this sensor goes wrong it usually takes out it's associated fuse which is usually a 5A one.
    This fuse always powers other functions as well as the Air Quality sensor.
    Have a look in your owners book to see if you can identify the fuse, otherwise check carefully all the 5A fuses.
    In fact check all the fuses.
    It might just be preventing the car from starting.
  1. 13 Weeks, Not too bad!
    By Berisford in forum Golf MK6 - 2009 - 2013
    Last Post: 30-09-2010, 06:50 PM
  2. Please Help Non starter - suspect starter motor.
    By 94golfcl in forum Golf MK3 - 1993 - 1999
    Last Post: 18-01-2010, 10:09 AM
  3. Attention knackered CAT on car I've had for 3 weeks!
    By con1981 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-08-2009, 06:37 PM
  4. Please Help left standing, now smoking starter motor
    By michaelchunt in forum Golf MK3 - 1993 - 1999
    Last Post: 31-12-2008, 07:02 AM
