Thread: non starter after being left for two weeks
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: non starter after being left for two weeks
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    I was going to get a new cluster and get it coded originally but I cant find anyone who is prepared to do it , they all say audi a3 8p no chance mate ffs
  2. Re: non starter after being left for two weeks
    1836 Post(s)
    It will only work with a new genuine cluster, I have tried with used clusters and lost hours of my life and will not try anymore and anyone with any sense will do the same.
  3. Re: non starter after being left for two weeks
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Got the cluster back and still non starter , towed it to our local garage and bump started it , now it is fine for starting , our local garage seems to think it was some sort of fuel lock , scanned it tonight and I have multiple fault codes and now I have steering sensor fault as well , I'm sick to death of this piece of **** car . Ps it drives fine but just now has orange steering wheel light on , brake error light , aux heater faults , can bus errors etc etc , I will put tonight's scan on here for you all to laugh at .
  4. Re: non starter after being left for two weeks
    Near Blackpool
    48 Post(s)
    Steering will probs clear after a drive? Unless there’s something in the brake system.
    Canbus errors are normally in door looms where it goes body to doors.
    Aux heaters have failed in them all due to valeo and their absolutely barbaric design.
    Least it drives
    1 1 0
  5. Re: non starter after being left for two weeks
    1836 Post(s)
    Clear the codes, drive the car, ignore the POS useless aux heater code, it is nearly as useless as the rear wiper motor, also made by the company which has done more to damage the reputation of VAG than any other, Valeo... they make the seventies laughing stock of “Lucas, prince of darkness” look like an example of excellence... how does the company survive?
  6. Re: non starter after being left for two weeks
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    It has been for short drives today and the steering wheel warning light is still on and comes back straight away if I clear it , this has only come on since I had the battery off the car to charge it while the cluster was away being checked .
  7. Re: non starter after being left for two weeks
    #17
    Near Blackpool
    48 Post(s)
    Might just need angle sensor calibrating. Full left hold for 10 full right hold for ten dead straight hold for 10. Key off and out for 30 seconds. Post scan and it’ll be more obvious
  8. Re: non starter after being left for two weeks
    #18
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Code:
    #9BBBBTuesday,18,August,2020,20:27:04:53651
    VCDS Version: 17.1.0.0
    Data version: 20170106 DS267.0
    Ross-Tech: Home
    VIN: WAUZZZ8P47A039226   License Plate: CE56GYJ
    Mileage: 219490km-136384mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 77 7D
    VIN: WAUZZZ8P47A039226   Mileage: 219490km-136384miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine        Labels: 03G-906-018-BMN.clb
       Part No SW: 03G 906 018 DN    HW: 03G 906 018 DN
       Component: R4 2.0l PPD1.2 G    1247
       Revision: --H22---    Serial number: AUX7Z0F6FNJ01J
       Coding: 0000072
       Shop #: WSC 66565 257 00032
       VCID: 74E7BAF5176ABCE1DB-8020
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
       Component: ESP FRONT MK60      0101
       Revision: 00H11001
       Coding: 0023170
       Shop #: WSC 06314 000 00000
       VCID: 73E5B9E91264BBD9C2-8026
    Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
       Part No SW: 8P0 820 043 N    HW: 8P0 820 043 N
       Component: KlimavollautomatH18 0300
       Revision: 114439      Serial number: 8P0820043N
       VCID: 377D4DF9469C17F93E-8062
    2 Faults Found:
    00483 - Control Module for Auxiliary Air Heater
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 27
                        Mileage: 219474 km
                        Time Indication: 0
                        Date: 2020.07.27
                        Time: 00:08:04
                 Freeze Frame:
                            ON
    01592 - Air Quality Sensor (G238)
                010 - Open or Short to Plus
                 Freeze Frame:
                        Fault Status: 01101010
                        Fault Priority: 3
                        Fault Frequency: 20
                        Reset counter: 29
                        Mileage: 218801 km
                        Time Indication: 0
                        Date: 2020.05.21
                        Time: 18:08:46
                 Freeze Frame:
                        Temperature: -50.0°C
    Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
       Component: Bordnetz-SG     H43 1201
       Revision: 00H43000    Serial number: 00000006000401
       Coding: E4885F01B214100000160000160000000008FA175C0100
       Shop #: WSC 06314 000 08192
       VCID: 408F2625135250418F-8014
       Subsystem 1 - Part No: 8P2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H01 0130
       Coding: 00062736
       Shop #: WSC 06314
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0090
       Coding: 00150573
       Shop #: WSC 06314
    2 Faults Found:
    00988 - Lamp for Brake Light; Right (M10)
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 31
                        Mileage: 219455 km
                        Time Indication: 0
                        Date: 2020.07.12
                        Time: 11:19:00
                 Freeze Frame:
                            ON
                        Voltage: 14.20 V
                            ON
                            ON
                            OFF
                            OFF
                            ON
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 67
                        Mileage: 0 km
                        Time Indication: 0
                 Freeze Frame:
                            ON
                        Voltage: 10.75 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    Address 15: Airbags        Labels: 8P0-959-655-94.lbl
       Part No SW: 8P0 959 655 C    HW: 8P0 959 655 C
       Component:    Airbag 9.41  H12 3760
       Revision: 91H12376    Serial number: 003620G1AKGV
       Coding: 0071612
       VCID: 428B2C2D1D5E425199-8016
       Subsystem 1 - Serial number: 6332DRB4037DCAB40
       Subsystem 2 - Serial number: 6342DRB4037D89B2.
       Subsystem 3 - Serial number: 63528RB401701602/
       Subsystem 4 - Serial number: 63628RB4017010471
       Subsystem 5 - Serial number: 63729RB401733F22G
       Subsystem 6 - Serial number: 63829RB401733EDE$
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H34 0070
       Coding: 0000022
       VCID: 418923211858594980-8014
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
       Part No SW: 8P0 920 951 D    HW: 8P0 920 951 D
       Component: KOMBIINSTR. VDO H18 0560
       Revision: D0H18002    Serial number: 1246F002001098
       Coding: 0004403
       Shop #: WSC 80093 222 69422
       VCID: 366340FD4196EEF125-8062
    4 Faults Found:
    01299 - Diagnostic Interface for Data Bus (J533)
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 3
                        Reset counter: 40
                        Time Indication: 0
    00779 - Outside Air Temp Sensor (G17)
                007 - Short to Ground - Intermittent
                 Freeze Frame:
                        Fault Status: 00100111
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 67
                        Time Indication: 0
    00771 - Fuel Level Sensor (G)
                010 - Open or Short to Plus - Intermittent
                 Freeze Frame:
                        Fault Status: 00101010
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 67
                        Time Indication: 0
    00562 - Sensor for Oil Level/Temperature (G266)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 67
                        Time Indication: 0
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Part No SW: 1K0 907 530 J    HW: 1K0 907 951
       Component: J533__Gateway   H12 0160
       Revision:   H12       Serial number: 320010662787F6
       Coding: 3D3F0BC207002103
       VCID: 2E53689DB9C6D6316D-807A
    1 Fault Found:
    00381 - Databus Instrument Cluster
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 1
                        Fault Frequency: 7
                        Reset counter: 27
                        Time Indication: 15
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Revision: D0H18002    Serial number: AUX7Z0F6FNJ01J
       Shop #: WSC 57285 003 1048576
    1 Fault Found:
    16346 - Control Module - ROM Error
                014 - Defective
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
       Part No: 8P0 959 801 H
       Component: Tuer-SG         020 0090
       Coding: 0000760
    Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.079 H07 1806
       Shop #: WSC 02069 000 90108
       VCID: 356147F15C90E5E92C-8060
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
                000 -  -
    Address 46: Central Conv.        Labels: 8P0-959-433.lbl
       Part No: 8P0 959 433 C
       Component:    KSG          H04 0050
       Coding: 188000186D088505489FC63300
       VCID: 3C7752D57FBA34A1D3-8068
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 8P0 951 177
       Component: Innenraumueberw.H04 0020
    Address 47: Sound System        Labels: 8Px-035-382.lbl
       Part No SW: 8P4 035 382     HW: 8P4 035 382
       Component: AB2 SUBWOOFERBOXH04 0180
       Revision: 00003       Serial number: 30674526449165
       Shop #: WSC 00000 000 00000
       VCID: 71E9B3E1687889C930-8024
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
       Part No: 8P0 959 802 H
       Coding: 0000760
    Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
       Part No SW: 8P0 035 186 C    HW: 8P0 035 186 C
       Component: concert II EU   H52 0100
       Revision:      02S    Serial number: AUZ2Z3F4225280
       Coding: 0001021
       Shop #: WSC 06435 000 00000
       VCID: 326B7CEDADFEF2D109-8066
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 67
                        Mileage: 219474 km
                        Time Indication: 0
                        Date: 2020.07.27
                        Time: 01:05:50
                 Freeze Frame:
                        Bin. Bits:       10
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No: 8P4 959 801 D
       Component: Tuer-SG         020 0070
       Coding: 0000216
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No: 8P4 959 802 D
       Coding: 0000216
    Address 77: Telephone        Labels: 8P0-862-335.lbl
       Part No SW: 8P0 862 335 H    HW: 8P0 862 335 H
       Component: FSE_255x BT     H21 0290
       Revision: 00000001    Serial number: 00000000504452
       Coding: 0000120
       VCID: 3B7551C97AB43399DA-806E
    Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
       Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
       Component: PTC-Element         0404
       Revision: 00800000    Serial number:
       VCID: 2D516F91B4C0AD2954-8078
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
                014 - Defective
    End-------------------------(Elapsed Time: 02:22)--------------------------
    Address 09: DTCs cleared
    Address 46,8P0 959 433 C,channel 1,adapted from,1,to,1,
  9. Re: non starter after being left for two weeks
    #19
    Near Blackpool
    48 Post(s)
    That’s after you’ve cleared it and driven it again?
  1. 13 Weeks, Not too bad!
    By Berisford in forum Golf MK6 - 2009 - 2013
    Last Post: 30-09-2010, 06:50 PM
  2. Please Help Non starter - suspect starter motor.
    By 94golfcl in forum Golf MK3 - 1993 - 1999
    Last Post: 18-01-2010, 10:09 AM
  3. Attention knackered CAT on car I've had for 3 weeks!
    By con1981 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-08-2009, 06:37 PM
  4. Please Help left standing, now smoking starter motor
    By michaelchunt in forum Golf MK3 - 1993 - 1999
    Last Post: 31-12-2008, 07:02 AM
