Hi all just purchased a fox 1.2 2009. Drive it home. Everything fine. Next day I headed out on a longer run and it overheated or red temperature light came on.
in the end it looked like the fan wasn’t working or coming on so I ordered a radiator temp sensor and a one for the engine just to be sure. As a short term measure I shorted the fan out so it would run on a temporary switch until my parts arrived but on my run out this has now stopped working and the light came on again. I’m no good with vehicle electrics but I have checked the fuses in the car under the steering wheel and are all ok. I no longer have A 12v circuit from the fan wiring. Any thoughts on my next steps.
ps all hoses hot, car heater works fine. Water trickle seen back to expansion bottle on first check.
