Thread: Audi brake shim
  1. Audi brake shim
    Aug 2020
    Sittingbourne, Kent
    I just found out, after miles done with squeaky brakes, that my caliper shims are missing. From 2 per caliper, one at the top and one at the bottom, I only have one on the left side. Apparently they are very important however very expensive and impossible to find them cheaper.
    Part code for top is 4M0615269
    Part code for bottom is 4M0615269C
    Does anyone have any idea besides the dealer where can I find them? If not it would have to be a dealer job, around 250£ including fitting.
  2. Re: Audi brake shim
    Mar 2018
    GB
    19 Post(s)
    Who serviced or changed the pads last?
    If it was a company or a dealer then take it back to them.
    Sent from my SM-G950F using Tapatalk
  3. Re: Audi brake shim
    Jan 2018
    Warsaw
    65 Post(s)
    Quote Originally Posted by AlexFota View Post
    Ask them:
    Bremsbeläge Montage Kit Shims vorne Quick Brake 109-0030 G NEU OE Ersatz | eBay
    or them:
    Audi Brake Shim - Genuine Audi VW 4M0615269 | FCP Euro
  4. Re: Audi brake shim
    1841 Post(s)
    These were revised mid 2016 as they often fly out and to cure it you have to fit the revised calipers at £570 each. You could try and find the METZGER pad fitting kit 109-0030 such as the usual Accessory Kit, disc brake pads METZGER 109-0030 — Buy now!
  1. Replies: 4
    Last Post: 30-05-2016, 12:21 AM
  2. Please Help Audi A4 B7 Brake Lights
    By winny in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 16-08-2015, 11:30 AM
  3. Brake rotors for an Audi 90
    By Pete@ECSTuning in forum 80 - 90
    Last Post: 29-12-2009, 07:43 PM
  4. Please Help 92 Audi 80 2.3e Brake problems
    By casperthefriend in forum 80 - 90
    Last Post: 25-04-2009, 11:31 PM
  5. audi 80 brake lines
    By robert1z in forum 80 - 90
    Last Post: 02-03-2009, 06:00 PM
