Thread: Audi s4 2013 noise from underneath petrol tank after engine switched off
  1. Audi s4 2013 noise from underneath petrol tank after engine switched off
    May 2017
    Can anyone identify what this noise is ?
    Happens after a run in the car . Engine off and Ignition off. High pitch pulsing sound from underneath petrol tank . Went on for ages . Eventually stops if I remove petrol cap . Air rushes out and can hear gurgling inside tank . May have to remove cap several times before it stops .
    Car also making a humming / drone type noise coming from rear of car when moving above 20 mph but possibly unrelated (wheel bearing/ drive shaft bearing?). Help on this also appreciated.
  2. Re: Audi s4 2013 noise from underneath petrol tank after engine switched off
    Apr 2009
    Fuel tank breather blocked.
    Sent from my MI 6 using Tapatalk
    Audi A4 Avant 2.0 TDi 2009
  3. Re: Audi s4 2013 noise from underneath petrol tank after engine switched off
    May 2017
    Thanks Shaka . Any idea where itís located and how to unblock it ? And what causes it to become blocked ?
  1. diesel tank leaking fuel out everywhere underneath car ??? any know tank problems
    By dazbo1972 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-09-2014, 10:50 PM
  2. weird noise from underneath car
    By Imran in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-12-2013, 03:09 PM
  3. water dripping underneath the expension tank 2.4 v6 2002
    By scanny1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-04-2012, 09:16 PM
  4. Switched from petrol to diesel
    By keano03 in forum New Member Introductions
    Last Post: 02-03-2011, 12:59 PM
  5. Odd noise when engine switched off
    By thedeeg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-06-2009, 09:05 PM
