Thread: Help needed please for the door actuator threaded rod measurement
  1. Cool Help needed please for the door actuator threaded rod measurement
    May 2020
    Margam United Kingdom
    Hi Guys and Gals
    I have just had to change my drivers door actuator (front right) it was a big struggle to get it out , despite being advised to mark the threaded rod it, which was not going to happen because I could not reach it.
    So now I have a new actuator arriving estimated delivery Tue, 04 August - Thu, 06 August.
    When I got the old one onto the bench it is well past it's "use by date", glad it happened this time of the year as opposed to the winter etc.
    So basically I am asking at what position do I locate this rod, any help please would be extremely useful.
    Please see attachment
  2. Re: Help needed please for the door actuator threaded rod measurement
    1836 Post(s)
    Replicate the original, trip the lock latch over to imitate door being shut and test, adjust until happy
  3. Thumbs up Re: Help needed please for the door actuator THIS PROJECT NOW SORTED THANKS
    May 2020
    Hi there
    Many thanks for contributing to my thread.
    Just so I have this clear in my head, are you saying, install the new actuator in the car, then push the locking mechanism until the lock thinks its closed.
    I have understood that bit.
    Then adjust the threaded rod ! ! !
    I partially understand that but its a really tight squeeze getting one hand in let alone two hands.
    Can I put it another way
    Before the lock goes in and I have a bit more room to work, what is going to be closest to the desired position ?
    All the way up to the end i.e going towards the glass OR all the way down so it's just about to drop off the threaded rod.
    I look forward to your response.
    Tony
  1. Please Help 2003 vw beetle 1.6 cabriolet door actuator
    By PIBBLE in forum Beetle 2000-
    Last Post: 10-06-2019, 12:01 PM
  2. Please Help Rear door won't open!! (not actuator!)
    By Boogins in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-01-2019, 01:16 PM
  3. Door actuator failure, trim removal
    By mtbkitch in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-03-2016, 08:30 AM
  4. Replies: 6
    Last Post: 16-11-2015, 05:36 PM
  5. Help needed - removing a threaded bolt on Rocker cover
    By bio10155 in forum Archive posts
    Last Post: 10-02-2008, 09:09 PM
