Thread: OBD2 fault codes but no warning light
  1. OBD2 fault codes but no warning light
    Jul 2020
    Leeds, UK
    Hi, I'm new to the forum and apologise if this is in the wrong section:
    I recently scanned my car (Audi A3 2017) with an OBD2 scanner. It produced 3 error codes:
    P332500 - Power supply terminal 15, Implausible;
    P157000 - Engine Control Module (ECM) disabled;
    P334B00 - Charge pressure actuator, mechanical malfunction.
    I wondered if these were significant? I should mention that there has been NO warning lights appear at all in the few months I have owned the car (3 years old). Could these codes be stored in the computer from a previous, resolved issue? Or are they simply not significant enough to prompt a warning light? Had I not scanned that car I would have been completely unaware of anything. The car drives fine with absolutely no noticeable issues.
    Many thanks,
    Ian
  2. Re: OBD2 fault codes but no warning light
    East Kent
    The standard thing to do when you scan a car for which you don't know the history is:
    Scan for faults [just to see what's there]
    Clear all the faults [temporary faults or cleared faults will disappear]
    Scan for faults again [to see what's faulty now]
    Julian
    By the way; many ECU 'faults' don't set any lights
  3. Re: OBD2 fault codes but no warning light
    Jul 2020
    Leeds, UK
    Hi Julian,
    Thanks for your response, much appreciated.
    I cleared the faults at the time and they haven't returned.
    Ian
  1. Engine management light and glow plug light errors/fault codes
    By zhussain087 in forum Golf MK6 - 2009 - 2013
    Last Post: 26-06-2020, 03:32 PM
  2. Fault codes p0322 and p0321 engine idle high, cutting out Eml light and epc light on
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-05-2018, 10:58 AM
  3. ABS Warning light, No fault codes.
    By k_h in forum Golf MK4 - 1999 - 2004
    Last Post: 04-09-2011, 04:40 PM
  4. Bad idling, EPC warning and fault codes after welding on exhaust
    By Robin_N in forum Golf MK4 - 1999 - 2004
    Last Post: 18-05-2010, 09:12 PM
  5. Question One for the experts, air bag warning ligh and fault codes
    By tony g in forum Golf MK4 - 1999 - 2004
    Last Post: 27-12-2009, 03:28 PM
