Thread: Drivers front window dead
  1. Drivers front window dead
    Nov 2018
    Tamworth
    22 Post(s)
    Hi all,
    2014 1.6 diesel 5 door - son's car
    Drivers electric window is dead, fortunately in the up position.
    VCDS gives this (after clearing all the historical codes ):
    Chassis Type: 5F-SE37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
    VIN: VSSZZZ5FZER081161 Mileage: 147315km-91537miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    5F-Information Electr. -- Status: OK 0000
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
    Component: TSG FS 009 0014
    Serial number: 0000088332083
    Coding: 00100220C001040000001000
    Shop #: WSC 00049 770 00128
    ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
    ROD: EV_DCUDriveSideEWMAXCONT.rod
    VCID: 44D0BA03FE13ADAB373-8010
    Drivers Door Rear Control Module:
    Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
    Component: FOND_FHSG_DRV 005 0005
    Serial number: 00000000000001489767
    Coding: 2D0000
    1 Fault Found:
    65589 - Motor for Window Regulator
    B1487 13 [009] - Open Circuit
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 63
    Mileage: 147315 km
    Date: 2020.07.29
    Time: 10:01:54
    I'm not getting much from Google searches . Being "old" an open circuit suggests to me a broken wire?????
    All help gratefully received.
    Andy.
  2. Re: Drivers front window dead
    1836 Post(s)
    Disconnect the door conduit unit by lifting it up and pulling it away from the door and open up the tubing, check the thick brown and red/yellow wires... they snap. These wires are very difficult to repair effectively so when we encounter it we suggest a new harness which in this cars case is Seat number 5F4 971 030 AL and retails at £70.52 which is only an hours labour. It is a bit fussy to change when you go inside the kick panel as there are a lot of plugs.
  3. Re: Drivers front window dead
    Nov 2018
    Tamworth
    22 Post(s)
    Cheers, Crasher.
    As always, thanks.
    Andy.
  1. Front drivers side window regulator
    By JonesyA6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-03-2017, 08:00 PM
  2. Question Front left window lift (drivers side)
    By Switzz in forum Octavia
    Last Post: 08-08-2015, 05:13 AM
  3. 2004 front drivers window problem (goes down but only goes up sometimes)
    By JDM-A4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-12-2014, 07:17 PM
  4. Please Help Wind noise, Drivers side front window
    By granttd73 in forum Golf MK5 - 2004 - 2009
    Last Post: 08-09-2014, 02:55 PM
  5. Front Drivers Window
    By passat se in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2009, 10:29 PM
