Thread: Non starting, Brake light on
Results 1 to 10 of 14
  1. Non starting, Brake light on
    Jun 2007
    Hi, 2008 A3 1.4. Will not start and brake light on. AA called out, he disconnectd battery and reconnected again-no difference. Suggested dirty terminals to ECU. Disconnected cables, sprayed contact cleaner and reassembled. No difference immediately but started next day with no faults reading. This has now happened again after 1 week. Any suggestions, Thanks in advance.
  2. Re: Non starting, Brake light on
    Feb 2020
    Bradford
    40 Post(s)
    Quote Originally Posted by Bob Heritage View Post
    Does it crank?
    If not check brake switch and clutch master cylinder circuits. First thing to check would be to pull the plugs off for any possible overheating
  3. Re: Non starting, Brake light on
    Jun 2007
    Thanks for your suggestion, I will try that tomorrow, ( No it doesn't crank, completely dead apart from dash lights)
  4. Re: Non starting, Brake light on
    Nov 2017
    Newmilns
    Could immobiliser be getting engaged ? Is there fuel in the tank ? On a Mazda I had - the fuel pump packed in - so no fuel getting to engine.
  5. Re: Non starting, Brake light on
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Usually when your battery is on its way out you will get the big red brake fault symbol.Its Audis way to suggest that there is a problem with the brakes, thus ensuring you dont drive the car until professional investigation.
    You naturally check your pads/discs/fluid etc and find nothing wrong and carry on driving the car,A short time on you get starting irregularities and then non starting, battery finished.
    The reason they dont want you to drive with a weakening battery is because of all the cars various safety systems which rely on a perfectly working electrical system.
    I am surprised the AA man did no checks on the battery condition rather than assuming ECU issues.
    Look, if this sends you up the wrong path and you do in fact have other issues Im sorry I couldnt help this time but it is a commonly known thing in the Audi owners world, good luck
    Stuart
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  6. Re: Non starting, Brake light on
    Oct 2009
    10 Post(s)
    I just read the original post again and am sure you battery is finished or not being fully recharged,battery dud or circuit not charging
    Good luck
    Stuart
  7. Re: Non starting, Brake light on
    Feb 2020
    Bradford
    40 Post(s)
    Must admit I am favouring the suggestion of Stuart over what I said earlier. I confused brake light (dash) for rear brake lights (a symptom which can inhibit starter operation)
  8. Re: Non starting, Brake light on
    Jun 2007
    Thanks again for your suggestions, The battery is only a couple of months old, Exide 4yr warrenty, I did put jump leads on it just in case something was wrong, but no change. Probably a connection somewhere as it sprang back into life for a week last time.
  9. Re: Non starting, Brake light on
    Jun 2007
    Update on my daughters A3. Today I have dismantled feeds to ECU again and sprayed contact cleaner on them and recharged the battery to full. I have also had a scan reader plugged in but it was unable to read/make contact. Do you think it could be a faulty ECU, if so ,can they be repaired? (Central locking works fine) Also any advise on system readers and which one to buy? can they be bought second hand.
    Thanks again.
  10. Re: Non starting, Brake light on
    Nov 2017
    Newmilns
    I bought a reader from ebay - not cheap £60 - the one I got suited my car - This is the link - maybe check if there is a system reader for your car from vendor
    Items for sale by oem_diagnostic_solutions | eBay
    2013 A3 1.6tdi sportback
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  3. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
  4. Replies: 1
    Last Post: 09-09-2010, 04:36 PM
  5. A4 1.8T beep flahing brake light and not starting
    By 5up3rman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-07-2010, 09:15 AM
