Thread: Non starting, Brake light on
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Non starting, Brake light on
    #11
    Jun 2007
    Thanks for your suggestions so far. I have now fitted a new brake sensor and still no change. Daughter now tells me that it has happened about 3 times before but always starts if left a couple of minutes {but not in this case) if I could get communication with diagnostics it would help.
  2. Re: Non starting, Brake light on
    #12
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Have you looked at the VCDS users map.
    https://www.vwaudiforum.co.uk/forum/showthread.php/5319-Vagcom-VCDS-User-Locations
    There may be someone local who could scan it for you.
    If you get your own scanner I would only choose OBDEleven or VCDS.
    Other makes may not give you all the available info.
  3. Re: Non starting, Brake light on
    #13
    Jun 2007
    Thanks for your suggestion of scanner, had a look and they are quite expensive for the VCDS ones, I realise that you get what you pay for, but wondered if they become available second hand
  4. Re: Non starting, Brake light on
    #14
    Jun 2007
    Ive had a couple of mechanics look at the car and they both said ECU was faulty. I bought an exchange ready programmed ECU for £380. Fitted it and still the same, so not ECU. I'm thinking along the lines of immobilizer now, any suggestions how to go about this?
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  3. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
  4. Replies: 1
    Last Post: 09-09-2010, 04:36 PM
  5. A4 1.8T beep flahing brake light and not starting
    By 5up3rman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-07-2010, 09:15 AM
