Thread: Solved... 4F top arm bolt removal
Results 1 to 10 of 12
  1. Solved... 4F top arm bolt removal
    Jul 2009
    uk
    My son replacing my front shocks and springs.
    He has sheared the top wishbone bolt clamping the ball joints.
    Is this a standard bolt and what size as I have odd bits in my garage.
    thanks
    2010 A6 C6-Avant 2.7 TDi LeMans (FaceLift)
  2. Re: Front suspension top wishbone bolt info
    1837 Post(s)
    On a 98>04 4B the bolt is M10x100x1.5 10.9 tensile. There is a special tool for getting the bolts out but it is ****, the best way is to heat the upper cast iron neck around the ball joints until the bolt can be hammered out BUT that does destroy the ball joints although new upper arms are cheap. If it had the later aluminium uprights as on your 4F, these are a sketch as heating the ally can make it crack and you can be into £1k of parts per side to put it right.
    Drift stages
    if the new dampers have fixed lower spring plates, the damper pre instal alignment is vital
    the 8E type with alloy uprights was one thing
    but later on the 8K type they turned the bolt around and made it impossible and there are no tools to help BUT thankfully they turned the inner mounts bolts around giving you a way out of cracking the alloy
  3. Re: Front suspension top wishbone bolt info
    Jul 2009
    uk
    It looks like I may have to renew the upright. Despite heating with a plumbers gas gun and WD40, with a 4lb flogger against the ball joint area and using a 2lb hammer to hit the bolt out.
    It just wont budge.
  4. Re: Front suspension top wishbone bolt info
    1837 Post(s)
    Normal, it is the cast iron upright so get some proper heat in there, I now use a 2Kw induction heater instead of the old gasaxe.
  5. Re: Front suspension top wishbone bolt info
    Sep 2016
    12 Post(s)
    This may help you, a friend with the same problem brought the upright round to me to see if we could together get it removed.
    Up to that point it'd been heated, partly drilled out, and had a hardened punch snapped off down inside the hole!!!
    It wouldn't move at all with hammering, absolutely solid like it was part of the structure.
    We'd all but given up, but tried it with a SDS hammer drill with rotary stop (just hammering) using an old drill shank with tungsten tip removed and ground flat, just positioned it on a block of hardwood and rattled it continuously. After about ten minutes (mostly deaf at this point as it makes a helluva racket) it started to show signs of movement, dust and corrosion coming out of joint etc. Once past that it freed up and withdrew.
    We didn't think we were going to get it, but that hammering is so insistent, saves you clobbering your knuckles with a lump hammer too, a good attribute
    0 2 0
  6. Re: Front suspension top wishbone bolt info
    1837 Post(s)
    We use an air chisel with a pointed drift to do the same thing.
  7. Re: Front suspension top wishbone bolt info
    Jul 2009
    uk
    OK,
    Update. Had to cut the top arms to remove the knuckle. Using brute force of all suggestions above, no joy in removal.
    A chap in a local garage got it out fairly easy, he managed to weld a stub to the siezed broken bolt. Attached a welding set to heat the bolt to release the corrosion and poured red diesel to cool it and soak over night. Next day used a drift and knocked the bolt out.
  8. Re: Front suspension top wishbone bolt info
    Jul 2009
    uk
    Could a Mod please mark this as 'Solved' and move the thread to the 'C6' section as it is a C6 (2010)
    thanks
  9. Re: Front suspension top wishbone bolt info
    Jul 2013
    76 Post(s)
    Hi Crasher,
    Can you confirm the angle, is it 11 degrees +/-2 degrees? as i have seen a TB for this but that was for a A4.
    Dan
    2009/2010 2.0 TDIe SE
  10. Re: Front suspension top wishbone bolt info
    1837 Post(s)
    Which car?
  1. Question Locking Wheel Bolt Removal
    By stu_rat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-02-2019, 11:48 PM
  2. Solved solved all issues posting this to help and share what i solved
    By maxim2014 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-04-2017, 12:41 AM
  3. Golf Plus 2005 wheel bolt cap removal tool
    By EmuGriff in forum Wheels and Tyres
    Last Post: 11-02-2012, 11:49 AM
  4. Pinch bolt/spring removal
    By toadus in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-04-2011, 04:30 PM
  5. A6 bolt removal problems
    By ajc in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-12-2009, 02:16 PM
