Thread: Lt35 intstrument screen crack repairs ?
  1. Lt35 intstrument screen crack repairs ?
    Jul 2020
    new zealand
    Im a newbie and have a question re my 2006 LT35 motorhome.
    The speedo panel has several fine cracks in the instrument panel face / screen .
    Can this be replaced or repaired with a clear repair .Must be a weakness in the screen design ?
    Hoping someone has experienced this issue
    Read somewhere that acetone can fuse plastic together with a good clear result ??
    thanks
    Bryan
  2. Re: Lt35 intstrument screen crack repairs ?
    1840 Post(s)
    You cannot buy the screen, only the complete unit which is £400 plus installation programming to match the vehicle and the later is not at all straightforward outside of the VW commercial dealer network.
  3. Re: Lt35 intstrument screen crack repairs ?
    Jul 2020
    new zealand
    Ouch ,but thanks for that .Will have to try a repair .
    Bryan
  4. Re: Lt35 intstrument screen crack repairs ?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Are you getting the effect where cracks all the way through the acrylic create a dark or shiny "strip" where light is blocked by the crack?
    I think you'll struggle with acetone, or any welding chemical, unless you take the acrylic out and can lay it flat to push the pieces together using acetone or (perhaps better as a one-time-only try) a display case adhesive like Loctite 9483. Not sure if the plastic used is acrylic / Perspex or a polystyrene, and the best adhesive for optical outcome may differ.
  5. Re: Lt35 intstrument screen crack repairs ?
    Feb 2017
    Yorkshire
    Any update? Are you done repairing it?
  6. Re: Lt35 intstrument screen crack repairs ?
    Jul 2020
    new zealand
    Acetone has partially worked but still looks horrible .
    Will have to leave it I think as removal etc is beyond me thanks
  1. PD 150 crack problems
    By welchy74 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-02-2010, 11:15 PM
  2. Please Help WIndscreen Crack
    By Naveid4u in forum Golf MK4 - 1999 - 2004
    Last Post: 15-11-2009, 02:10 PM
  3. Crack in the windscreen - who to use?
    By Foxtrot Oscar in forum Golf MK6 - 2009 - 2013
    Last Post: 09-10-2009, 11:05 AM
  4. Question Crack in dash!!
    By audia4tdv in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-07-2009, 07:31 AM
  5. What's the Crack
    By wstrain87 in forum New Member Introductions
    Last Post: 19-09-2008, 03:58 PM
