Thread: Throttle valve adaption - no option in vcds?????
Results 1 to 8 of 8
  1. Throttle valve adaption - no option in vcds?????
    Oct 2015
    nottingham
    Hi hope someone can help? I have a 2008 A5 3.0TDI QUATTRO and have fitted a new Throttle body - it is dropping the revs off at idle and throwing up the the following fault codes :-
    'implausible position signal'
    'open circuit intermittant'
    Do i need to run an adaption? - problem is there is no option in VCDS, BASIC SETTINGS drop down to do it?
    Or have i been sold a faulty new unit ?
    I bought a Febi - 46601 T.B
  2. Re: Throttle valve adaption - no option in vcds?????
    Oct 2015
    nottingham
    Sorry ignore the 'implausible signal' that is a faulty swirl flap actuator on bank 1 , must have failed recently ..... typical!
    please help with the throttle issue though????
  3. Re: Throttle valve adaption - no option in vcds?????
    1837 Post(s)
    We need the code number
  4. Re: Throttle valve adaption - no option in vcds?????
    Oct 2015
    nottingham
    Yes the 2 codes are 5301- Throttle actuator control circuit p2100 00 [100] and 5308 - throttle body actuator bank 1 (j338) p0638 00 [036] I have just fitted back the rough sounding old unit, and both codes have cleared?
  5. Re: Throttle valve adaption - no option in vcds?????
    1837 Post(s)
    That is the correct Febi number to replace 4E0 145 950 J (£532.50 inc VAT genuine) and it would be highly unusual for a Febi part to be faulty but it does suggest it is. If I had been doing the job now I would have had to go for a Pierburg unit (roughly £450 retail, £479.99 Euro Car Parts retail) as they are on backorder with Febi which does concern me.
  6. Re: Throttle valve adaption - no option in vcds?????
    Oct 2015
    nottingham
    Thanks Crasher, just a quick one - why do i not have the option to Adapt in VCDS? - is it because i don't need to? Thanks.
  7. Re: Throttle valve adaption - no option in vcds?????
    1837 Post(s)
    There is no adaptation, plug and play.
  8. Re: Throttle valve adaption - no option in vcds?????
    Oct 2015
    nottingham
    Thanks very much
  1. Question EGR Valve Replacement and Adaption to ECU 2.0TDi (170) BRD
    By sanstorm999 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-12-2018, 08:02 AM
  2. Question THROTTLE BODY adaption error AHW engine
    By sharanthing1 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-04-2015, 06:12 PM
  3. Throttle Re-Adaption - Polo 1.4
    By Stue in forum Polo - Derby - Lupo - Fox
    Last Post: 15-08-2010, 01:15 AM
  4. Throttle body adaption really necessary?
    By Withnail in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-02-2010, 10:47 PM
  5. 1.8 agn non turbo throttle adaption
    By wayne4776@hotma in forum Golf MK4 - 1999 - 2004
    Last Post: 15-01-2009, 06:08 PM
