Thread: 2 G or 3 G
  1. 2 G or 3 G
    Dec 2013
    Liverpool
    10 Post(s)
    How do I identify if I have MMI 2g or 3g????
    2007 2.7 SE quattro saloon
  2. Re: 2 G or 3 G
    Sep 2011
    Kilmarnock, United Kingdom
    12 Post(s)
    The easiest way is to check the software version that is loaded in the system. To do this, enter the car menu by pressing the CAR button, then press SETUP or MENU, then select the “Version” submenu and read the value from the line marked with the letters “SW“.
    MMI 2G: SW: XX-XX XX.X.X XXXX
    MMI 3G Low/Basic: BNav_XX_XXXXX
    MMI 3G High: HNav_XX_XXXXX
    MMI 3G+: HN+_XX_XXXXX or HN+R
    MMI RMC: RMC_XX_XXXXX
    MMI Mib1: MHIG_XX_XXXX
    MMI Mib2: MHI2_XX_XXXX
    MMI MSTD: MSTD_XX_XXXX
  3. Re: 2 G or 3 G
    Jul 2013
    76 Post(s)
    You have 2g if your car is a 2007 model.
    3G started on the faclifts in late 2008.
    Dan
    2009/2010 2.0 TDIe SE
  4. Re: 2 G or 3 G
    Dec 2013
    Liverpool
    10 Post(s)
    Thanks guys.
    This only begs another question. Is there anything between the OEM Aerial (in quarter light) and the DAB Module that could be causing the loss many stations or could it be I need to upgrade to DAB+. if the upgrade is needed then what can I upgrade with????
    If I do a scan with VCDS what do I need to scan and what should I be looking for?
  5. Re: 2 G or 3 G
    Jul 2013
    76 Post(s)
    If you have the OEM glass with the DAB attenna in your car and you are getting no fault codes i would suspect that there most likely is a dry joint within the Radio unit, the fakra connection in the radio would first place to look, the electronics in the Radio unit are now 13 years old in your car so components can be life expired.
    I have the 3G DAB fitted in my car and it drops out all over the place, our other car a ford Kuga, the DAB is rock solid everywhere.
    Dan
  6. Re: 2 G or 3 G
    Dec 2013
    Liverpool
    10 Post(s)
    Just checked I have MMI 2G.
    this is my scan with VCDS, can anyone see anything
    Sunday,26,July,2020,13:08:26:20402VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.2.2 (x64)
    Data version: 20200210 DS308.0
    Ross-Tech: Home
    VIN: WAUZZZ4F38N057899 License Plate: KH57 TGU
    Mileage: 228890km-142225mi Repair Order:
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 06 07 08 09 0E 0F 13 15 16 17 19 36 37 42 46 47
    4F 52 53 55 56 61 62 67 69 72 76 77
    VIN: WAUZZZ4F38N057899 Mileage: 228890km-142225miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    0F-Digital Radio -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    67-Voice Control -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 059-907-401-BPP.clb
    Part No SW: 4F5 910 401 K HW: 4F0 907 401 C
    Component: 2.7L V6TDI A000AG 0030
    Revision: --H05--- Serial number:
    Coding: 0011372
    Shop #: WSC 02629 005 00000
    VCID: 2959D1DA80B69007D2-807C
    1 Fault Found:
    005495 - Right Engine Mount Solenoid Valve (N145)
    P1577 - 001 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 254
    Reset counter: 255
    Mileage: 226051 km
    Time Indication: 0
    Date: 2020.04.10
    Time: 14:35:13
    Freeze Frame:
    RPM: 1344 /min
    Torque: 163.8 Nm
    Speed: 2.2 km/h
    Voltage: 13.76 V
    Bin. Bits: 1
    Bin. Bits: 0
    Bin. Bits: 0
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 S HW: 09L 927 156 C
    Component: AG6 09L 2,7 TDI 132 0020
    Revision: --H04--- Serial number: 4374019
    Coding: 0000002
    Shop #: WSC 02325 758 00200
    VCID: 35610DAA5C0EC4E746-8060
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.clb
    Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
    Component: ESP8 quattro H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004488
    VCID: 66C39AE651287F7F3F-8032
    Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0230
    Revision: 09010701 Serial number: 10601500882587
    Coding: 0000023
    Shop #: WSC 02323 758 00200
    VCID: 63C583F2A21A0A57D8-8036
    Subsystem 1 - Part No: 4F0 910 131 G
    Component: FBSAUDIC6 EZS H45 0080
    Subsystem 2 - Part No: 4F0 910 335
    Component: FBSAUDIC6 KSG H27 0080
    Subsystem 3 - Part No: 4F0 910 220 K
    Component: FBSAUDIC6 IDG H01 0060
    Address 06: Seat Mem. Pass Labels: None
    Part No SW: 4F0 910 760 HW: 4F0 959 760
    Component: Sitzmemory BFS H04 0050
    Revision: 00000000 Serial number: 00000000896400
    Coding: 0078944
    Shop #: WSC 02334 758 00200
    VCID: 61C989FAB8061847CA-8034
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350IX077823746
    Coding: 0000002
    Shop #: WSC 02335 758 00200
    VCID: 2541DDEAECAEB467F6-8070
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H01 0060
    Subsystem 2 - Serial number: 00000000877151
    Subsystem 3 - Serial number: 0127.09.070000000100010567˙
    Subsystem 4 - Serial number: 010567˙
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
    Component: KLIMABETAETIGUNGH30 0020
    Revision: 00000052 Serial number: 00000000446585
    Coding: 0001046
    VCID: 1C37F80EDFE475AF59-8048
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H18 0250
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0003121
    VCID: 316939BAA866E8C71A-8064
    Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0100
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
    Component: MP3-Changer H46 0390
    Revision: 00046006 Serial number: AUZ5ZBG3485967
    Shop #: WSC 00000 000 00000
    VCID: 1A3BFE16D5D00B9F4B-804E
    Address 0F: Digital Radio Labels: None
    Part No SW: 4E0 910 563 C HW: 4E0 035 563
    Component: DAB-Tuner H41 0830
    Revision: 00000001 Serial number: KE1276V7200514
    Coding: 0000001
    Shop #: WSC 06325 000 00000
    VCID: 2447C0EEE7944D6FE1-8070
    Address 13: Auto Dist. Reg Labels: 4F0-910-561.lbl
    Part No SW: 4F0 910 561 C HW: 4F0 907 561 B
    Component: ABSTANDSREGELUNGH02 0020
    Revision: -------- Serial number: 00000000000000
    Coding: 0051151
    VCID: 2345C3F2E29A4A5798-8076
    Address 15: Airbags Labels: 4F0-910-655-8R.clb
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH30 0280
    Revision: 09H30000 Serial number: 0037LD0U6EY%
    Coding: 0013381
    Subsystem 1 - Serial number: 6332CSME2A710576%
    Subsystem 2 - Serial number: 6342CSME2A71457DB
    Subsystem 3 - Serial number: 6352QSME3C714141A
    Subsystem 4 - Serial number: 6362QSME395113336
    Subsystem 5 - Serial number: 63734SME412D1A37%
    Subsystem 6 - Serial number: 63834SME4016263D.
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0410
    Revision: 00H03000 Serial number: 90054072620587
    Coding: 0102151
    VCID: 275DD7E296A2A677C4-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 981 J
    Component: KOMBIINSTR. M73 H21 0220
    Revision: 00300000 Serial number: 64D55DA47
    Coding: 2241458
    Shop #: WSC 12345 001 136936
    Address 19: CAN Gateway Labels:. 4L0-910-468.clb
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 C
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1000D077288075
    Coding: F7D19F77317A0600
    VCID: 2D5125CAB45E8C273E-8078
    Address 36: Seat Mem. Drvr Labels: None
    Component: Sitzmemory FS H04 0050
    Coding: 0074858
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
    Component: MNS ECE H50 1060
    Revision: 00000000 Serial number: 364I$077717934
    Shop #: WSC 00164 210 89663
    VCID: 3B751B927A2A1297B0-806E
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0210
    Revision: 00-00000
    Coding: 0019098
    Shop #: WSC 02327 758 00200
    VCID: 2C5728CE8F44852F29-8078
    Address 46: Central Conv. Labels:. 4F0-910-289.lbl
    Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
    Component: Komfortgeraet H25 0200
    Revision: 02000025 Serial number: 01067694080000
    Coding: 0131579
    Subsystem 1 - Component: Sounder No Answer
    Subsystem 2 - Component: IRUE No Answer
    3 Faults Found:
    01135 - Interior Monitoring Sensors
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Reset counter: 144
    Mileage: 141510 km
    Time Indication: 0
    Date: 2014.05.11
    Time: 12:23:37
    01134 - Alarm Horn (H12)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 89
    Reset counter: 200
    Mileage: 141510 km
    Time Indication: 0
    Date: 2014.05.11
    Time: 12:40:04
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 144
    Mileage: 142003 km
    Time Indication: 0
    Date: 2014.05.23
    Time: 17:27:33
    Address 47: Sound System Labels: 4F0-910-223-BO.lbl
    Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
    Component: DSP-High C6 H10 0240
    Revision: PROD_01 Serial number: 00000000049083
    Coding: 0000023
    Shop #: WSC 02324 758 00200
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H12 0100
    Revision: Serial number: 00000000345710
    Coding: 0001103
    VCID: 5EB3B206897827BFF7-800A
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0210
    Revision: 00-00000
    Coding: 0019226
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000521
    VCID: 204FCCFEF38C514F85-8074
    Address 55: Headlight Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
    Component: AFS 1 H01 0020
    Coding: 0000016
    Subsystem 1 - Part No: 4F0 941 329 D
    Component: AFS-Modul links H01 0010
    Subsystem 2 - Part No: 4F0 941 329 D
    Component: AFS-Modul rechtsH01 0010
    1 Fault Found:
    02628 - Sensor for Swivel Module Position; Right
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00111000
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 40
    Mileage: 227080 km
    Time Indication: 0
    Date: 2020.06.04
    Time: 07:50:21
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 394I+077815826
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000140516
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 0709252388
    Coding: 344630393135313035442056413030373039323532333838
    Shop #: WSC 00000 512 00290
    1 Fault Found:
    02272 - Quiescent Current Stage 1
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 225939 km
    Time Indication: 0
    Date: 2020.04.03
    Time: 14:19:45
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0210
    Coding: 0018434
    VCID: 2E5322C6B958F73F07-807A
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
    Component: SDS 3502 UK H46 0630
    Revision: 00000000 Serial number: 00000709180112
    Shop #: WSC 12336 024 394758
    VCID: 36630AA64108CFFF4F-8062
    Address 69: Trailer (J345) Labels:. 4F0-907-383.clb
    Part No SW: 4F0 907 383 C HW: 4F0 907 383 C
    Component: Anhaenger H14 0080
    Revision: 2B002001 Serial number: 00000106122910
    Coding: 0103030000000000
    Shop #: WSC 02399 823 56573
    VCID: 2B552BD24A4A821720-807E
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0210
    Coding: 0018434
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
    Component: Parkhilfe 8-Kan H12 0080
    Revision: 00H12000 Serial number: 06320726303307
    Coding: 0211006
    Shop #: WSC 131071 1023 2097151
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H18 1130
    Revision: 00000000 Serial number: 00000005028013
    Coding: 0010900
