Thread: Do I need a new timing chain or not? Audi A5 1.8 TFSI CAB engine
  1. Do I need a new timing chain or not? Audi A5 1.8 TFSI CAB engine
    Apr 2016
    peterborough
    Hello,
    Anyone can tell me if I need a new timing chain or not. My symptoms are, car misfiring on idle, still able to drive fine no loss of power and I can hear a rattle sound on cold start at idle. Which lead me to believe I need a new timing chain as I have seen online these engines are known for chain tensioner issues and chain stretching. I have some paperwork for misfiring, car was taken to Audi to fix the misfire as engine light was on with a misfire code in cylinder 2. They cleaned out the injectors to find the problem still persists. I dont know much about the previous history as I just bought the car but hearing the rattle on idle makes me think it needs a new timing chain?
    I have some pictures of measuring values of the ignition timing adjusment cylinder 1 which on idle is always negative.. Lowest I have seen is -7.5 degrees. If you rev the car and hold the revs, the figures go positive but on idle they will stay negative.
    116050650_217649109489547_5039504229115549623_n.jpg116397702_673386036593392_7061375342205064264_n.jpg116217094_673864183196827_1586747386279676697_n.jpg
    Is this issue timing chain related or is there a bigger issue with the car? No misfire codes present at the moment on VCDS. Seems like all 4 cylinders are misfiring according to VCDS?????
  2. Re: Do I need a new timing chain or not? Audi A5 1.8 TFSI CAB engine
    Apr 2016
    peterborough
    Anyone know if timing chain can cause misfiring? Thanks.
  3. Re: Do I need a new timing chain or not? Audi A5 1.8 TFSI CAB engine
    108 Post(s)
    1816 Post(s)
    Yes, very common.
  1. Question A3 2.0 TFSi Engine Management Emissions Control Light / Timing Chain Replacement
    By simmons123 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-07-2017, 09:26 PM
  2. Question Audi A3 2007 s-line 1.4 tfsi timing chain slip
    By TomShep97 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-06-2016, 04:47 PM
  3. Audi A3 1.4 TFSi timing chain intervals?
    By 220TC in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-01-2016, 01:02 AM
  4. A3 1.4 TFSI Cold Start Rattle - Timing Chain related?
    By Rudedog in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-07-2015, 10:40 AM
  5. 2010 (March) - 1.8 TFSI - Timing Chain or Belt?
    By _tones in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-12-2013, 06:58 PM
