Thread: Front suspension knock
  1. Front suspension knock
    Dec 2013
    Liverpool
    10 Post(s)
    Some help / advice needed if possible please.
    I have recently notices a "slight knocking from what appears the front suspension, only really happens on uneven road surface. I had the front lower rear control arms replaced on both sides as it was an MOT advisory, but now this "knocking" is really annoying me. I am now suspecting it is from the top of the suspension, what parts are the most common culprit. It has been on an MOT ramp on the shaker plates an it is not knocking but thats more side to side, not up and down.
    2007 2.7 SE quattro saloon
  2. Re: Front suspension knock
    Jul 2013
    76 Post(s)
    The first item to check are the anti-roll bar links (stabiliser links), are the bushes worn.
    Then check the upper arm links as they may have worn the ball joints or the bush on each arm.
    Have you had the brake pads changed as loose pads can cause a knocking noise when the car moving over bumps.
    Google Audi SSP 324 for an in depth understanding of the suspension setup.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Front suspension knock
    Dec 2013
    Liverpool
    10 Post(s)
    Cheer's Dan, no new brake pads fitted, so that has ruled that one out.
    Anti roll bar looks like the easiest to do.
    How difficult are the upper control arms to change?
    the google search was interesting, was wondering if the it could be the shock absorber mounting, are there any rubber parts there?
  1. Help. Knock from d/s front suspension
    By Jdot in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-02-2016, 04:39 PM
  2. Front suspension knock
    By Dave Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2009, 03:49 PM
  3. Audi A6 front suspension knock
    By rosssomerville in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-03-2009, 12:04 AM
  4. Re Audi A6 front suspension knock
    By geoff4e in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-02-2009, 04:49 PM
  5. Front suspension knock....
    By randall977 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-02-2009, 11:12 AM
