Thread: Polo 1.2Tsi cam belt change eng CJZC
  1. Polo 1.2Tsi cam belt change eng CJZC
    Aug 2007
    Hook Hampshire
    21 Post(s)
    My project for September is to replace the cam belt on a Polo 6C1 1.2TSi CJZC engine. Looking at the procedures, it appears to be straightforward with the right tools, but at the end there is a procedure for checking the valve timing. Does this have to be done on each belt change or can it be checked an easier way.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: Polo 1.2Tsi cam belt change eng CJZC
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Ah, Having read the instructions again its a simple case of .........The camshaft clamp -T10494- must slide into position easily..... If that happens when the crankshaft is against the stop bolt, then the timing is correct.
  1. Battery Charger for 2016 Polo 1.2TSi with Stop Start
    By Golfer Phillip in forum Polo - Derby - Lupo - Fox
    Last Post: 19-02-2017, 09:08 PM
  2. Please Help 53 REG 1.9 SDI Polo Twist - Cam Belt change
    By andymg in forum Polo - Derby - Lupo - Fox
    Last Post: 15-01-2012, 01:41 PM
  3. Question Info on Polo 1.2TSI...
    By PoloTDI in forum Polo - Derby - Lupo - Fox
    Last Post: 07-03-2011, 10:47 AM
  4. Polo AHW Timing Belt change
    By Jamiem in forum Polo - Derby - Lupo - Fox
    Last Post: 10-09-2010, 10:11 PM
  5. New Polo 1.2tsi
    By kjg-kj in forum Polo - Derby - Lupo - Fox
    Last Post: 13-03-2010, 09:28 PM
