Thread: Air suspension...
  1. Air suspension...
    Jan 2010
    Newport
    Hi all,
    Just wondering if anyone can help me out with a couple of problems I'm having with my A6 Allroad....
    About a year ago I had the air suspension system give up on me so had the air compressor replaced, everything fine since. Just recently I had had the air suspension caution light come on again so had it checked at my local garage who changed the suspension valve block but the problem has reoccurred. Garage now seems to think that its a communications issue but I'm not so sure.
    Also have an intermittent problem with the parking brake where the warning comes on and the parking brake light flashes but does work.
    Had a diagnostics check done and I have the following showing:
    Electrohydr Brake
    U111300 | ABS/TCS/ESP CAN signal | Signal faulty
    Adapt susp sys 4.0
    C104707 | Level valves | Mechanical fault
    C104600 | Level control | Plausibility
    C10C800 | Function deactivation | Component / function active
    Centr electronics
    0A38 | Tank flap release motor | Open circuit/ground short
    0A37 | Tank flap locking motor | Open circuit/ground short
    Really appreciate any help!
  2. Re: Air suspension...
    Oct 2019
    Peterborough, England
    23 Post(s)
    One of my EPBs had an issue, turned out it had a massive slice through the cable. Worked in the summer, but come cold and wet, it highlighted it and I had to change it. So check the cabling to the rear calipers.
    suspension wise, was the control relay changed at the same time? These can be a weak point and at only £5, worth chang8ng.
  3. Re: Air suspension...
    Jan 2010
    Newport
    Thanks A8, I'll have a good look at the cabling for the EPB. The problem was certainly more common during the winter. It hasn't happend for a while now so sounds lile a good steer..
    The control relay wasnt changed, but again sounds like a good place to go next.
    Much appreciated!
  1. Please Help Front suspension spring and suspension arms
    By Stavros_Davros in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-06-2018, 02:16 PM
  2. Audi A6 c7 2013 allroad suspension problems (or any c7 with air suspension)
    By Audrius in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-01-2015, 10:53 PM
  3. Self Levelling Suspension Fault - Locked Suspension Yelow Warning on Dash
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 05:01 PM
  4. S Line suspension vs Sports Suspension - Retro fit
    By scoobmw in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-10-2010, 09:23 AM
  5. Mechanical differences between Sport suspension and ordinary suspension
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-06-2010, 05:03 PM
