Thread: Bkd clutch change
Results 1 to 8 of 8
  1. Bkd clutch change
    Nov 2013
    west midlands
    Friend has a 2.0 bkd golf that was fitted with a solid flywheel and clutch
    They have changed to a dual mass but have major issues
    Car won’t turn over
    Starter smokes when used a lot
    Car won’t bump start
    Car won’t bump start with starter removed
    The gearbox engages fine and the clutch works perfect
    Are the flywheel bolts different for both flywheels the engine feels like it’s locked up and won’t turn over
  2. Re: Bkd clutch change
    Oct 2018
    York
    9 Post(s)
    The dual mass flywheel and clutch shouldn't per se cause any problems - the flywheel bolts that attach each respective part - SMF, DMF - may well be different, but the flywheel bolts are torque-to-yield items and should only ever be used the once. They also usually come with the flywheel and clutch assembly as bought, so this shouldn't be an issue.
    It sounds like the starter may be suspect - can you replace with a known good one? Though having said that, my BKD starts quickly even though I know the starter is old and knackered.
    My first thought would be the starter. And, if the starter has been getting so much abuse that it's smoking, perhaps the battery no longer has enough power to provide the injectors with the juice they need to operate?
  3. Re: Bkd clutch change
    Nov 2013
    west midlands
    They have gone from a solid clutch to a dual mass
    The clutch is new but the dual mass and all the bits old I assume
    I only say as we have jump started the car using 3 batteries and off 2 cars
    Down the massive hill the car jams solid and stops
  4. Re: Bkd clutch change
    Nov 2013
    west midlands
    Just a update
    Taken the gearbox off and the insides wrecked the person who fitted it fitted the clutch with too long bolts and the clutch pressure plate has been catching the bell housing
    They are putting it back together but no idea of the damage to clutch etc
  5. Re: Bkd clutch change
    Oct 2018
    York
    9 Post(s)
    Oof. Sorry to hear that. Good luck with getting it sorted.
  6. Re: Bkd clutch change
    Nov 2013
    west midlands
    Bitter pill to swallow for them trying to do things without paying out
    A set of 5 quid bolts would have saved ripping the gearbox out again
    The car starts but doesn’t sound great so god knows what damage has been caused
  7. Re: Bkd clutch change
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Ideally send a lawyer letter giving them a reasonable time to make good all damage due to not using reasonable skill and care, advising that if they refuse you'll get the work done elsewhere and ask them for payment. I'd put 14 days as that period as it's a relatively simple job and parts should be easily accessible. If they refuse get the work done elsewhere (3 quotes including VAG), pay, send invoice to original place and pursue through MCOL (previously Small Claims) if necessary.
    If paid on credit card that may be route to get original cost back, but probably not consequential damage.
  8. Re: Bkd clutch change
    Nov 2013
    west midlands
    It was done by a mechanic but as a favour to his missus brother so at his house I did say I wouldn’t have attempted it if they didn’t want to supply all the bits but his answer my hands are tied I just want a quiet life lol
  1. Clutch change
    By craigtaylor in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-05-2015, 07:51 PM
  2. A3 Clutch change help
    By glover in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 14-08-2010, 11:08 PM
  3. Clutch change
    By vroooOOOM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-12-2009, 07:25 AM
  4. Clutch Change
    By j4s0n88 in forum Golf MK5 - 2004 - 2009
    Last Post: 24-04-2009, 08:25 PM
  5. Clutch Change 1.4 8v
    By Gunzi in forum Polo - Derby - Lupo - Fox
    Last Post: 10-11-2007, 01:15 PM
