Thread: Error on roof shade. 1 fault found, attached.
  1. Error on roof shade. 1 fault found, attached.
    Jan 2020
    Norway
    Hi!
    Five days after the warranty expired the steering gear stopped working on the first day of our holliday (costing 4500 Euro...) Two days after picking the car up from three week repair the sun roof shade stopped working so I am very happy with my Audi now... It has been working fine all the time, but suddenly when I tried to open the roof shade after closing it, it`s dead. When trying to open the roof shade nothing happens. When trying to close it (although it is already closed) the motor makes a sound so it seems like it has power. I checked for errors now and got the fault below. Can anyone help me to solve this problem?
    Control Module Part Number: 4M0 907 594 HW: 4M0 907 594
    Component and/or Version: SAD_STG_1 011 0003
    Software Coding: 608000053602
    Work Shop Code: WSC 03846 002 1048576
    ASAM Dataset: EV_SunRoofCONTIAU736 004008 (AU73)
    VCID: 73B3DEB67B3138435E9-8026
    1 Fault Found:
    0274 - Roof Shade
    B1544 54 [009] - Missing Calibration / Basic Setting
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 57
    Mileage: 93994 km
    Date: 2020.07.19
    Time: 16:28:49
    Roof Blind-Position: not normed
    Roof Blind-Direction of movement: Not moving
    Roof Blind-Norming: not normed
    Roof Blind-Excessive temperature protection: not active
    Roof Blind-Reversing: not active
    Roof Blind-Adaption depth: 100 %
  2. Re: Error on roof shade. 1 fault found, attached.
    Jan 2020
    Norway
    Has anybody got a clue what to do..? Is it any way to manually open the shade so I can just forget about the problem for a while? The sun roof works fine, but the the sun roof shade stays closed...
  3. Re: Error on roof shade. 1 fault found, attached.
    Feb 2019
    MIDDLESBROUGH UK
    13 Post(s)
    Hi Larserso,
    Not sure if this applies to the 4M but on my old 4L model my sunroof blind got all tangled up once and forgot where it was.
    To reprogram it you had to operate close button continuously , after about 10-15 seconds it started moving forward and back until it set the limits up again.
    There was also a allen key slot on the motor to operate manually but being at the rear it was a bit of a pain to get to.
    As I say not sure if it will work on your car but worth a try.
    Good Luck
  1. 1 Fault Found:
    By gdallas in forum VCDS - General Questions
    Last Post: 01-02-2013, 11:00 PM
  2. I bought VCDS and found an error :(
    By Guest 2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-04-2011, 07:50 PM
  3. Audi Convertible roof error
    By sparticus in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2010, 02:30 PM
  4. Fault found : 01203
    By dylanlaw1979 in forum VCDS - General Questions
    Last Post: 06-06-2010, 07:11 PM
  5. Fault found after vag-com scan. Help??
    By ickleric in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2008, 11:46 PM
