Thread: 2.0Tdi BRE No Start
Results 1 to 10 of 10
  1. 2.0Tdi BRE No Start
    Feb 2015
    Europe
    Hi all,
    2006 Audi 2.0Tdi BRE wont start...
    History of issue,
    2 months ago - Replaced Battery with new Bosch 019 and coded in with VCDS.
    1 month ago - If car is standing for more than 2 days, cycle ignition & got low battery warning on DIS before starting. Check faults with VCDS and see some related to the battery regulator - quiescent current stage 1 - 5 etc. Recode battery with VCDS and check voltage at the alternator, jump terminals and battery. All showing 13.9V when car is running. Battery is 12.7V cold next morning before starting. All is good with charging.
    Last week - Started car cold in morning, hesitated to start (like it was misfiring) but fired up. Noticed over next day or so it was again hesitating to start but then started fine after driving and warmed up.
    Recently - Started car cold in the morning and it wouldn't start after numerous attempts, finally managed to start it and revved it to 2k rpm and it then the motor powered off completely, again managed to start car and left it idle but the motor powered off after 10 seconds. Videos here for reference...
    https://streamable.com/zrlqv1
    https://streamable.com/z5b9dx
    Discussed issue with a good mechanic and he reckons its an electrical problem so it's probably uneconomical to fix due to the labour time etc. Water did get into the passenger footwell around 6 months ago or so and I cleared out the plenum chamber and undone the drain holes.
    A number of VCDS codes point to the ECU, no comms etc...
    Code:
    Mileage: 294600km-183055mi
    Chassis Type: 4F (4F0)
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53 56
              61 62 72 76 77
    VIN: WAUZZZ4F87N07****   Mileage: 294600km/183055miles
    01-Engine -- Status: Malfunction 1010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    76-Park Assist -- Status: Malfunction 0010
    77-Telephone -- Status: Cannot be reached 1100
    Address 01: Engine        Labels: 03G-906-016-BLB.clb
       Part No SW: 03G 906 016 HS    HW: 03G 906 016 HS
       Component: R4 2,0L EDC G000SG  9673
       Revision: --H02---    Serial number:
       Coding: 0000072
       Shop #: WSC 66565 257 00032
       VCID: 7BF511673A10BBC6C11-802E
    3 Faults Found:
    000258 - Mass Air Flow Sensor (G70)
                   P0102 - 000 - Signal too Low - Intermittent
                 Freeze Frame:
                        Fault Status: 00110000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 293944 km
                        Time Indication: 0
                        Date: 2020.06.11
                        Time: 09:44:09
                 Freeze Frame:
                        RPM: 945 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Duty Cycle: 99.6 %
                        Bin. Bits: 00001100
                        Mass Air / Rev.: 700.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
    005716 - Please check DTC Memory of Instrument Cluster
                   P1654 - 000 -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 293965 km
                        Time Indication: 0
                        Date: 2020.06.11
                        Time: 12:08:35
                 Freeze Frame:
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Voltage: 11.70 V
                        Temperature: 26.1∞C
                        Temperature: 61.2∞C
                        Temperature: 26.1∞C
    012546 - Motor for Intake Manifold Flap (V157)
                   P3102 - 000 - No Signal - Intermittent
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Voltage: 5.47 V
                        Bin. Bits: 00001100
                        Torque: 0.0 Nm
                        Torque: 351.4 Nm
    Readiness: 0 1 0 0 0
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
       Component: ESP8 front      H01 0070
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0020855
       Shop #: WSC 02331 785 00200
       VCID: 65C1571FAC941D36075-8030
    3 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 6
                        Mileage: 294173 km
                        Time Indication: 0
                        Date: 2006.05.10
                        Time: 12:09:56
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x02A2
                        Hex Value: 0x0024
                        Hex Value: 0x017B
                        Hex Value: 0x00FF
    02083 - Message for Delay Request
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 21
                        Mileage: 294595 km
                        Time Indication: 0
                        Date: 2020.06.25
                        Time: 16:15:28
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x02A2
                        Hex Value: 0x002B
                        Hex Value: 0x0594
                        Hex Value: 0x00FF
    01314 - Engine Control Module
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 21
                        Mileage: 294493 km
                        Time Indication: 0
                        Date: 2020.06.24
                        Time: 12:28:12
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x02A2
                        Hex Value: 0x0013
                        Hex Value: 0x8888
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100565824
       Coding: 0000017
       VCID: E3C5C90722A0E306691-80B6
       Subsystem 1 - Part No: 4F0 910 131 D
       Component: FBSAUDIC6 EZS   H45 0080
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H01 0040
    No fault code found.
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F0 910 731 J    HW: 4E0 035 729
       Component: Interfacebox    H43 2860
       Revision: 00000000    Serial number: 350JX067727482
       Coding: 0000002
       Shop #: WSC 02335 785 00200
       VCID: 29591B2F800CF956E3D-807C
       Subsystem 1 - Part No: 4F0 910 609 E
       Component: Bedienteil MMIC6H02 0060
       Subsystem 2 - Serial number: 00000000548685
       Subsystem 3 - Serial number: 0111.10.060000000100011564ˇ
       Subsystem 4 - Serial number: 011564ˇ
    1 Fault Found:
    00003 - Control Module
                005 - No or Incorrect Basic Setting / Adaptation
                 Freeze Frame:
                        Fault Status: 01100101
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 223
                        Mileage: 294207 km
                        Time Indication: 0
                        Date: 2006.05.11
                        Time: 08:46:01
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043     HW: 4F2 820 043 N
       Component: KLIMABETAETIGUNGH20 0170
       Revision: 00000032    Serial number: 00000030171165
       Coding: 0001044
       VCID: DBB5F1E71AD0DBC6211-808E
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 L    HW: 4F0 907 279 B
       Component: ILM Fahrer      H15 0240
       Revision: 00000000    Serial number: 4F0907279
       Coding: 0000104
       VCID: 326BFC43ADDABA8E527-8067
       Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0190
       Coding: 00064784
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0090
       Coding: 00146221
       Shop #: WSC 02335
    4 Faults Found:
    01496 - Bulb for Fog-Lamps; Left (L22)
                010 - Open or Short to Plus - Intermittent
                 Freeze Frame:
                        Fault Status: 00111010
                        Fault Priority: 2
                        Fault Frequency: 14
                        Reset counter: 22
                        Mileage: 262136 km
                        Time Indication: 0
                        Date: 2006.05.12
                        Time: 08:45:00
    01500 - Bulb for Fog-Lamps; Right (L23)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 7
                        Reset counter: 22
                        Mileage: 262136 km
                        Time Indication: 0
                        Date: 2020.06.19
                        Time: 10:24:00
    01494 - Bulb for Parking Lamps; Left (M1)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 237
                        Mileage: 262136 km
                        Time Indication: 0
                        Date: 2020.06.16
                        Time: 12:11:00
    01498 - Bulb for Parking Lamps; Right (M3)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 237
                        Mileage: 262136 km
                        Time Indication: 0
                        Date: 2020.06.16
                        Time: 12:11:00
    Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBF8205811
       Shop #: WSC 00000 000 00000
       VCID: 1C3732FBDF5E1CFE68B-8049
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4E AIRBAG AUDI8RH29 0280
       Revision: 08H29000    Serial number: 0037LD0H6AMD
       Coding: 0013381
       Shop #: WSC 02325 785 00200
       Subsystem 1 - Serial number: 6332CSME13370E7B7
       Subsystem 2 - Serial number: 6342CSME13266443Y
       Subsystem 3 - Serial number: 6352QSME131238252
       Subsystem 4 - Serial number: 6362QSME13484861D
       Subsystem 5 - Serial number: 63734SME13513B19Z
       Subsystem 6 - Serial number: 63834SME12723829-
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenks‰ulenmodul H08 0230
       Revision: 00H08000    Serial number: 90055062560197
       Coding: 0102041
       VCID: E6C3D013D192962E8EF-80B3
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: Lenkradmodul    H07 0090
    Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4F0 920 981 F
       Component: KOMBIINSTR. M73 H18 0120
       Revision: 00600000    Serial number: 5HS50CDA6
       Coding: 2308443
       Shop #: WSC 80093 222 71269
       VCID: 23450907E2202306A91-8076
    1 Fault Found:
    00779 - Outside Air Temp Sensor (G17)
                007 - Short to Ground - Intermittent
                 Freeze Frame:
                        Fault Status: 00100111
                        Fault Priority: 7
                        Fault Frequency: 11
                        Reset counter: 21
                        Mileage: 294282 km
                        Time Indication: 0
                        Date: 2006.05.12
                        Time: 14:28:12
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 1300806A0282B8
       Coding: ECEE53CC1B3104
       Shop #: WSC 00029 210 86049
       VCID: 275D1D179618CF26F59-8072
    2 Faults Found:
    01303 - Telephone Transceiver (R36)
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 222
                        Mileage: 294173 km
                        Time Indication: 0
                        Date: 2020.06.16
                        Time: 12:09:50
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 18
                        Mileage: 294493 km
                        Time Indication: 0
                        Date: 2020.06.24
                        Time: 12:28:10
    Address 36: Seat Mem. Drvr
    Cannot be reached
    Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
       Component: MNS ECE         H48 1060
       Revision: 00000000    Serial number: 364JX067600919
       Shop #: WSC 00325 941 194763
       VCID: 3B75D1677A907BC6811-806E
    Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
       Component: TSG FA          H12 0120
       Revision: 00-00000
       Coding: 0002714
       Shop #: WSC 02327 785 00200
       VCID: 2C57E23B8FFEEC7E18B-8079
    1 Fault Found:
    02123 - Door Warning Light / Entry Light
                 Freeze Frame:
                        Fault Status: 00101100
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 7
                        Mileage: 294173 km
                        Time Indication: 0
                        Date: 2020.06.16
                        Time: 12:45:04
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01022332400000
       Coding: 0000251
       VCID: 2E53E833B9E29E6E36F-807B
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    1 Fault Found:
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
                009 - Open or Short to Ground - Intermittent
                 Freeze Frame:
                        Fault Status: 00101001
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 16
                        Mileage: 294202 km
                        Time Indication: 0
                        Date: 2006.05.10
                        Time: 13:11:00
    Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
       Part No SW: 4F0 910 223 G    HW: 4F0 035 223
       Component: Amp.-ASK        H10 0350
       Revision: 45S00001    Serial number: 01610060365012
       Coding: 0000013
       VCID: 224B0C03FD3A2A0EA27-8077
    1 Fault Found:
    02454 - Microphone Unit (in Front Roof Module) (R164)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 88
                        Reset counter: 237
                        Mileage: 294173 km
                        Time Indication: 0
                        Date: 2020.06.16
                        Time: 12:08:54
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 A
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000303597
       Coding: 0001104
       VCID: DEB3F8F309C2CEEE46F-808B
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 19
                        Mileage: 262136 km
                        Time Indication: 0
                        Date: 2020.06.24
                        Time: 12:28:00
                 Freeze Frame:
                        Voltage: 11.600 V
                        Temperature: 19.0∞C
    Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
       Component: TSG BF          H12 0120
       Revision: 00-00000
       Coding: 0002714
    Address 53: Parking Brake        Labels: 4F0-910-801.clb
       Part No SW: 4F0 910 801 B    HW: 4F0 907 801 A
       Component: EPB  CB4C0060   H04 0060
       Revision: --H04---
       Coding: 0000111
       Shop #: WSC 02324 785 00200
       VCID: 1F4D05F7CE4807E68D9-804A
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 18
                        Mileage: 294488 km
                        Time Indication: 0
                        Date: 2020.06.24
                        Time: 12:28:10
                 Freeze Frame:
                        Voltage: 10.66 V
                        Count: 241
    Address 56: Radio        Labels: 4E0-910-541.lbl
       Part No SW: 4E0 910 541 M    HW: 4F0 035 541 H
       Component: TUNER EU/US/RDW H42 0570
       Revision: 00000000    Serial number: 394J-067693421
       Coding: 0000001
       VCID: 2A5BE423850AF24EEA7
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
       Component: J0644 BEM       H12 0590
       Revision: 00000000    Serial number: 00000000133335
       Shop #: WSC 00000 384 00290
       Subsystem 1 - Part No: 4F0 915 105 D
       Component: von VA0  2610191133
       Coding: 344630393135313035442056413032363130313931313333
       Shop #: WSC 12345 384 00290
    5 Faults Found:
    02256 - Quiescent Current
                001 - Upper Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00110001
                        Fault Priority: 7
                        Fault Frequency: 8
                        Reset counter: 22
                        Mileage: 294245 km
                        Time Indication: 0
                        Date: 2006.05.11
                        Time: 17:10:57
    02272 - Quiescent Current Stage 1
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 7
                        Reset counter: 255
                        Mileage: 294284 km
                        Time Indication: 0
                        Date: 2020.06.19
                        Time: 10:25:36
    02273 - Quiescent Current Stage 2
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 3
                        Reset counter: 255
                        Mileage: 294284 km
                        Time Indication: 0
                        Date: 2020.06.19
                        Time: 10:32:03
    02276 - Quiescent Current Stage 5
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 294286 km
                        Time Indication: 0
                        Date: 2020.06.19
                        Time: 11:30:52
    02274 - Quiescent Current Stage 3
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 294286 km
                        Time Indication: 0
                        Date: 2020.06.19
                        Time: 11:34:26
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
       Component: TSG HL          H21 0050
       Coding: 0002050
    Address 72: Door, Rear Right
    Cannot be reached
    Address 76: Park Assist        Labels: 4Fx-910-283.lbl
       Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
       Component: Parkhilfe 4-Kan H09 0060
       Revision: 00H09000    Serial number: 06220627502588
       Coding: 0200006
    1 Fault Found:
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 14
                        Reset counter: 22
                        Mileage: 294173 km
                        Time Indication: 0
                        Date: 2020.06.16
                        Time: 12:50:26
    Address 77: Telephone
    Cannot be reached
    End   ---------------------------------------------------------------------
    Is there anything worth looking at in terms of relays etc, common wiring corrosion areas or any other ideas??
  2. Re: 2.0Tdi BRE No Start
    Jul 2008
    Lisburn
    15 Post(s)
    never had the star then stop in mine - but the esp fault and numerous others could be down to the relay that powers up all the control modules - mine started to play up just after i had a no start issue due to a full plenum chamber...
    cant remember the relay number but it lives below the ecu and there are plenty of posts on here about it
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: 2.0Tdi BRE No Start
    Feb 2015
    Europe
    Cheers mate, yeah I have been researching the issue online and came across and a number of threads on here and other forums that point to the 614 engine control relay or the terminal 15 - 370 relays under the drivers side dash...
    I went and had a look and removed the ECU box cover to find the bottom of the box submerged in water, on further examination I noticed the scuttle panel wasn't clipped onto the windscreen properly. Absolute disaster ffs.
    I don't have the 614 relay in my 06. Its seems to be a 404 engine control relay and a 100 starter motor relay as seen in the pic, ive ordered both so I'm hoping that will solve the issue. Ive noticed someone was at it before also because of the copper grease around the connectors. The wiring connected to those relays connectors seems quite corroded (Green) from being submerged in the water, im thinking should I try and clean them up somewhat...
  4. Re: 2.0Tdi BRE No Start
    Jul 2008
    Lisburn
    15 Post(s)
    when i stripped mine it was as goodas new - even inside the relay so i didn't hold out much hope but it fixed it. So i recon you are onto a winner now...
    Stewart
  5. Re: 2.0Tdi BRE No Start
    Feb 2015
    Europe
    Great stuff! did you clean up yours or just throw in the new relays?
  6. Re: 2.0Tdi BRE No Start
    Jul 2008
    Lisburn
    15 Post(s)
    there was nothign to clean with mine it was like new so i just threw it in. I would clean yours up of course - contact cleaner with a light brush, and d-40 to protect after maybe?
    Stewart
  7. Re: 2.0Tdi BRE No Start
    Feb 2015
    Europe
    Yeah that sounds good. Will keep posted. Thanks again mate
  8. Re: 2.0Tdi BRE No Start
    Feb 2015
    Europe
    Ok, to update the thread for future readers reference...
    On further examination of the ECU box I removed the relays and fuse holders and found that a previous owner had been at the loom because the wiring was split near the block connector and hand joined, noticed that 2 cables had come apart again most likely due to the water ingress.
    I also opened up the relays to inspect their condition and found water had entered them so I soaked them along with the wiring connector blocks and loom in white vinegar and salt solution and then bicarbonate soda to clean them all up. Then I properly soldered up the wiring and re-routed the loom at the end of the ECU box to the top of the box and put sealant around the wiring that enters the bulkhead at the top of the ECU box to prevent any future water ingress. Reconnected the same relays and also sealed the scuttle panel to the windscreen.
    All done and the car fired up on the first go, happy days!
  9. Re: 2.0Tdi BRE No Start
    Jul 2008
    Lisburn
    15 Post(s)
    cool glad you got sorted. thats an interesting cocktail to clean up where did you hear that from?
    Stewart
  10. Re: 2.0Tdi BRE No Start
    Feb 2015
    Europe
    Cheers mate. Yeah read about that solution online. Worked wonders!
    http://www.youtube.com/watch?v=TfEIEVrmzVw
  1. Please Help A3 2.0tdi bkd stalled won’t start
    By gcq7 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-05-2020, 09:13 PM
  2. A4 S-Line 2.0tdi won't start
    By farmerferret in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-02-2018, 01:04 PM
  3. Please Help 2.0TDI - wont start
    By brummieboy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-06-2013, 10:21 PM
  4. 2.0tdi cranking but won't start..
    By Messer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-12-2012, 10:13 PM
  5. Difficult hot start in Mk5 GOLF 2.0tdi
    By Polarman in forum Golf MK5 - 2004 - 2009
    Last Post: 05-04-2010, 01:17 PM
