Thread: P0562 fault code showing on diagnostics machine
  1. P0562 fault code showing on diagnostics machine
    Jul 2020
    Brierley Hill, England
    I have a 2009 A3 2 litre TDI. Fault code P0562 (low voltage) was showing up on my diagnostics machine . The engine management light illuminated 2 days ago. I took the car to a tried and trusted garage who confirmed my fault code finding. they tested the voltage on the battery and it was showing 13.4, it should be between 14.2 and 14.4. The main issue with this fault code is the alternator so I told them to fit a new one which they did. The engine management light is still on . I have tried to clear the light with my OBD tool but it keeps coming back on. i have checked the voltage on the battery and its perfect. Ive taken the car for a fast runout today , the lights still on.
    Has anyone came across this before and if so, what was the outcome?
  2. Re: P0562 fault code showing on diagnostics machine
    Nov 2017
    Newmilns
    Hi - not sure if this will help , I bought VCDS software which interrogates all the ECU areas in the car, (Engine,ABS etc) To my knowledge the OBD tool does not access all the ECU's therefore cannot clear the fault in those ECU's , the VCDS tool, however allows these to be cleared. In saying this, I have also found out that each ECU has a reset counter associated with each fault ,which after a pre-determined number of drive cycles appears to cause an auto reset of the code if the cause was fixed - so the light may go off eventually after numerous stop/start drive cycles - otherwise see if the garage can clear all faults from the ECU's.
  3. Re: P0562 fault code showing on diagnostics machine
    Jul 2020
    malt56, thanks for your reply. Taking the car to an auto electrician on tuesday. Will see what he says. I plugged in my diagnostics machine yesterday, light was still on. With the engine running i turned off the light using the obd tool. i kept the engine running and took car for a drive, the light stayed off. I got home turned the ignition off then turned it back on and the light came back on. Not happy.
    Thanks again for the reply.
  4. Re: P0562 fault code showing on diagnostics machine
    Nov 2017
    Newmilns
    I think all the ECU's for the various sections of the car can combine to light the engine light and that engine ECU may indeed log what the fault was caused by - BUT I think there is a original copy of the fault stored in with ECU related to the battery and its this one that needs to be cleared ( to my knowledge standard OBD diagnostics only clear the code from main (engine) ECU but does not clear the battery ECU - so everytime the car starts there will be a self check and I suspect the local fault code is being recopied to main ECU and thus putting engine light on again. VCDS software can access all ECU's and truly clear any faults logged within each ECU - anyway auto guy should be able to resolve either way
  5. Re: P0562 fault code showing on diagnostics machine
    Jul 2020
    thanks malt56...you know your stuff. Hopefully there will be a positive outcome on tuesday.
  1. Please Help OBDII fault code P0322 & P0688 Showing on 2001 - S6 Quattro
    By bigwul83 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-09-2014, 07:33 PM
  2. Radio signal issues (nothing showing up after diagnostics test)
    By deacs09 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-08-2013, 08:37 AM
  3. rsnd showing safe pin code
    By steve02 in forum In Car Entertainment
    Last Post: 29-01-2011, 04:54 PM
  4. Question p2096 code just replaced 02 sensor still showing
    By Penguinducky in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-07-2009, 06:41 PM
  5. A6 ABS fault and diagnostics
    By mattA6OJB in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-04-2009, 07:32 AM
