Thread: 1.6tdi A3 (2010)
Results 1 to 9 of 9
  1. 1.6tdi A3 (2010)
    Nov 2019
    Sheffield
    Afternoon all,
    Just doing maintenence on my audi and want to go a coolant change. Can somebody point me in the right direction on how to do it
    Had a look though the Internet and it seems you either remove bottom rad pipe or use drain plug. Do you have to remove the undertray to do either method? Send like is should be easier to do
    Anybody know where th drain plug is on this model?
    Kind regards
    James
  2. Re: 1.6tdi A3 (2010)
    1841 Post(s)
    Is it due a cam belt change?
  3. Re: 1.6tdi A3 (2010)
    Nov 2019
    Sheffield
    Good question, I'm actually trying to find that one out. Where can I find this information?
    Done 60k and had it five years since belt changed.
  4. Re: 1.6tdi A3 (2010)
    Feb 2020
    Bradford
    40 Post(s)
    For Golf 1.6tdi cayc Haynes mentions a drain outlet fitted to the coolant bottom hose end fitting, but it also mentions the possibility of not having one.
    On Golf's which I have worked on I have not found one to be present. Generally on vehicles they can be found on lower portions of the radiator ends, sometimes accessible from cut outs in the lower front trim, otherwise facing the engine.
    If not present the Haynes procedure is to remover expansion tank cap, remove lower radiator hose, both hoses from electric coolant circulation pump and one of the coolant hoses from the oil cooler.
    If you are looking to do a complete drain I'd also say to remove the lower of the egr cooler hoses. Also on the Golf 1.6tdi the "the bottom radiator hose" is not exactly at the bottom. It is about 1/4 if not a 1/3 way up the side, so not ideal for complete draining either.
  5. Re: 1.6tdi A3 (2010)
    Nov 2019
    Sheffield
    Thanks for they, when you did the coolant change do you put the car up on ramps? I don't have any so guessing will make it alot harder to do.
    Regards James
  6. Re: 1.6tdi A3 (2010)
    Nov 2019
    Sheffield
    Would you use either of these two oils for 1.6tdi?
    Audi/VW Quantum LONGLIFE 3 Oil – 5w/30 – 5 Litres – Rapid Auto Care
    Millers Trident Longlife 5w30 Engine Oil (5L)
    gclid=CjwKCAjwr7X4BRA4EiwAUXjbt5nrPptSiwR9VplW3JjI KvrPtXALbPF0gR5bQgD0KOA0whr9Gfm9HBoCO4QQAvD_BwE
    Regards James
  7. Re: 1.6tdi A3 (2010)
    Feb 2020
    Bradford
    40 Post(s)
    Quote Originally Posted by Jblakes84 View Post
    Regards James
    I don't usually use my ramps, either axle stands or I have some bricks that I can drive onto safely. The more you lift the vehicle the more comfortable it'll be to get it done.
  8. Re: 1.6tdi A3 (2010)
    Feb 2020
    Bradford
    40 Post(s)
    Regards James
    Don't want to write the millers off as I have no experience of them, I use the quantum longlife and I can report no egr or dpf problems after 180k miles/8 year old car, mostly short runs and only using supermarket fuel. I actually get it from Rapid autocare
  9. Re: 1.6tdi A3 (2010)
    Nov 2019
    Sheffield
    Yeah alot of ppl say they use it. Might just stick to that as pretty sure thats what they put in last service
  1. Audi A3 1.6tdi (2010)
    By Jblakes84 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-12-2019, 08:45 PM
  2. Question 2010 1.6tdi polo gear selector
    By weebrads in forum Polo - Derby - Lupo - Fox
    Last Post: 11-11-2019, 06:16 PM
  3. Egr touran 1.6tdi cr 2010
    By Runel77 in forum Touran - Sharan - Caravelle
    Last Post: 16-05-2016, 09:15 AM
  4. 2010 Golf plus 1.6TDI Remap
    By moccas1 in forum Golf MK6 - 2009 - 2013
    Last Post: 28-10-2014, 08:23 AM
  5. Audi A3 SPORTBACK 1.6TDI 2010
    By alice87 in forum Chat - Anything with wheels
    Last Post: 02-04-2014, 07:29 AM
