Thread: "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
Results 1 to 10 of 13
  1. "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
    Nov 2019
    Oxford, Oxfordshire
    Hi All,
    First of all wanted to say I really like this forum!
    So I have a bit of a weird issue with my VW Jetta 2009 2.0 TDI 16v CBD 120k miles.
    I've had it about a year and a half now, without any major issues.
    About 6 months ago, I suddenly had the "Engine Oil pressure Off" warning with alarm when I drove off from home (engine cold).
    As I was a bit scared, I immediately took it to a garage which was luckily only half a mile away.
    Once there, they suggested the oil pump had broken so they replaced it.
    Since then, I've driven around 7-8k miles and everything was fine (great mileage, very little oil usage)
    Two weeks ago though, the "Engine Oil pressure Off" alarm came back (after 5min of driving).
    Scared again, I immediately had my car towed back home.
    The next day, quite curious, I went for a testdrive and all was fine again.
    I then drove at least another 800 miles without any issues.
    Then yesterday, the message came back but this time it happened more frequently; drive for 10min, alarm again, cool down car, drives fine again for a few minutes, alarm again.
    I suspected the Oil pressure sensor might be glitchy, so I went ahead and replaced it.
    Sadly though, the "Oil pressure Off" alarm is still around.
    I was wondering if someone might know what the problem here is.
    The car is due a service in about 1k miles, but I didn't think initially that would be the problem.
    I`m also aware you need at least 1500-2000RPM to get the alarm, so with all the drives I made sure to go over that limit.
    I also believe this car doesn't have the dreaded balance shaft oil pump, so that shouldn't be the issue as well.
    In terms of oil, I use 5W30 as per the book, perhaps a thicker oil would help?
    Many thanks in advance.
    Kind regards,
    T
  2. Re: "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
    1836 Post(s)
    It needs an actual oil pressure check using a gauge plumbed into the oil pressure sensor fitting which is an M10x1 thread.
  3. Re: "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
    Nov 2019
    Oxford, Oxfordshire
    Thanks for the quick reply.
    I've ordered a pressure tester with a short knee coupling as it's really tight in there.
    I've read that 0.8bar idle and 2.0bar @ 2000RPM are good numbers, is that correct?
    Many thanks again
  4. Re: "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
    1836 Post(s)
    The spec is an absolute minimum 2Bar at 2K rpm at 80 degrees c oil temp using 5w/30 oil BUT to me ths too low and I want to see 3+ and 5+ when cold. A hot idle of 1 Bar+ is ideal. The maximum reading should not exceed 7Bar!
  5. Re: "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
    Nov 2019
    Oxford, Oxfordshire
    Thanks a lot!
    I will update in about a week when I have the pressure tester (can use my trusty triumph in the meantime).
  6. Re: "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
    1836 Post(s)
    Triumph what?
  7. Re: "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
    Nov 2019
    Oxford, Oxfordshire
    a 2-wheeler; speed triple, sadly not a car so probably doesn't really belong in this forum
  8. Re: "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
    Nov 2019
    Oxford, Oxfordshire
    New update!
    So I received my oil pressure tester kit today and measured 1.0 bar at idle with a cold engine.
    Weirdly though, once revving to 2k RPM the oil pressure drops off hard.
    I`m not sure if this can mean that the demand for oil causes a pick-up line/sump to block up, but I think it might also be that my kit starts to leak.
    As you can see in the image below, it's all a very tight fit, and I could barely make the non-drip fit.
    I therefore think that once the engine starts shaking and/or pressure increase it starts to leak.
    I`m ordering a short-knee adapter so that I`m certain that the non-drip is connected properly.
    Cheers!
  9. Re: "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
    1836 Post(s)
    Could be a blocked pickup, we bought a 2010 Passat CRTDI with a blown turbo due to sump sludge.
  10. Re: "Engine Oil Pressure Off" warning but runs fine, Jetta '09 2.0 TDI 16v CBD
    Nov 2019
    Oxford, Oxfordshire
    Thanks for the reply.
    Yeah the car has seen quite a few miles in its life, so will definitely check this out!
    Would be weird that the garage didn't pick this up when they replaced my oil pump a few months ago, but might have not been blocked enough.
    I`ll update tomorrow/monday on the new measurement with the correct installation.
    As long as the car has 1bar on idle, I think i`ll let it warm up a bit and see what happens to the pressure then, also at 2k RPM.
    Thanks again for your help.
  1. Please Help Engine warning light, "Emissions Garage" and faults across all 4 injectors and glowplugs, still running fine.
    By andrewtscott87 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-01-2016, 05:41 PM
  2. Oil Pressure Warning Light, Buzzer and Airbag light "On" with ignition "Off"
    By silver4444uk in forum Polo - Derby - Lupo - Fox
    Last Post: 01-12-2013, 12:19 AM
