Thread: BKP 2.0 TDI Lost Power Problem
Results 1 to 10 of 12
  1. Lightbulb BKP 2.0 TDI Lost Power Problem
    Jul 2020
    Turkey
    Hello Everyone,
    I am from Turkey. I have a Passat BKP 2.0 TDI. The car is 103kW and it has got only a dtc code that is coolant temperature sensor on radiator outlet(18617).
    It's performance is poor, fuel consumption is high and warm start is hard (about 4 seconds). Turbocharger, egr valve and throttle flap valve renewed. I could not find any solution in Turkey.
    Can you help me? Thanks.
  2. Re: BKP 2.0 TDI Lost Power Problem
    1837 Post(s)
    Which diagnostic equipment do you have?
  3. Re: BKP 2.0 TDI Lost Power Problem
    Jul 2020
    Turkey
    I have Delphi 2016 Diagnostic SW.
  4. Re: BKP 2.0 TDI Lost Power Problem
    1837 Post(s)
    Can it do output tests? If it can, with the engine running, use address 11 (the engine speed will increase approx 300rpm) and watch the turbo actuator to see if it moves from min to max every 15 seconds or so.
  5. Re: BKP 2.0 TDI Lost Power Problem
    Jul 2020
    Turkey
    I don't know that can i do this test. But my diagnostic sw can monitor engine rpm, intake pressure and actuator duty. I will get screenshoot of this values's trend. Also i renewed the turbo actuator.
    When i monitor the turbo pressure, max pressure value is 1600 mbar. But target value of ECU is 2000mbar.
    Thanks.
  6. Re: BKP 2.0 TDI Lost Power Problem
    1837 Post(s)
    To watch the turbo actuator moving is very useful but replacing the actuator is risky without it being set up on a flow rig.
  7. Re: BKP 2.0 TDI Lost Power Problem
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by cmlozel View Post
    Hello Everyone,
    There are 2 coolant temperature sensors on 2.0 passat engines. This code is for the G83 in the coolant flange on the side of the head above the gearbox.
    Have you changed this yet?
  8. Re: BKP 2.0 TDI Lost Power Problem
    Jan 2016
    italy
    Hello Everyone,
    I have the same situation how did you solved?
    Sent from my SM-A125F using Tapatalk
  9. Re: BKP 2.0 TDI Lost Power Problem
    Jul 2020
    Turkey
    Quote Originally Posted by DMitch16 View Post
    Yeap, I did. Location is very hard.
  10. Re: BKP 2.0 TDI Lost Power Problem
    Jul 2020
    Turkey
    Quote Originally Posted by klisenko View Post
    Yes, I changed the clutch for performance.
    For a warm start, I repaired the starter motor.
  1. Question A4 B8 2.0TFSI has lost its power
    By John1292 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-09-2016, 09:38 PM
  2. A6 lost the power
    By semen in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-02-2009, 08:51 AM
  3. Please Help Lost Power
    By Stewaudi in forum Chat - Anything with wheels
    Last Post: 23-05-2008, 03:14 AM
  4. Lost power - MAF ?
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 04:54 PM
  5. Lost of power
    By windy1978 in forum 80 - 90
    Last Post: 12-02-2008, 08:16 AM
