Thread: 2.0 TDI Common rail diesel leak
  1. 2.0 TDI Common rail diesel leak
    Jun 2020
    2.0 TDI common rail in a 65 plate Crafter 35 LWB. Is leaking diesel out of the timing cover from under the drive gear for the high pressure fuel pump. Has anyone encountered this?
  2. Re: 2.0 TDI Common rail diesel leak
    1840 Post(s)
    Officially you cannot replace the seal, just fit a new pump with there are three variations according to vehicle spec.
  1. Were late B7's fitted with the 2.0L common rail diesel engine?
    By ming in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-11-2011, 06:23 AM
  2. Question Running In a Common Rail Diesel?
    By logiclee in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-06-2010, 11:43 AM
  3. Common Rail Diesel Engines
    By djah in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-05-2010, 08:07 PM
  4. Common rail diesel tuning/chipped/upgraded
    By Mike from Notts in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 12:38 AM
  5. Common rail diesel owners. A quick question.
    By CMcK in forum Golf MK5 - 2004 - 2009
    Last Post: 22-12-2008, 01:53 PM
