Thread: hot start problem 1.9tdi 2009
  1. hot start problem 1.9tdi 2009
    Jul 2020
    ireland
    Hello,
    I am really really stuck on this now,4 wks ago my skoda octavia mk2 1.9tdi 2009 would not start when engine was hot,cold starts no problem whatsoever,since then i firstly changed fuel pump as i rushed into panic,did not work.
    So after searching through forums and forums and some mechanics,i have since changed the coolant temp sensor,the crankshaft sensor,and on friday changed the starter motor and also the fuel filter.also had battery tested and tried to start when engine was warm with power pack,all through this if i disconnect the coolant temp sensor the car starts hot or cold but i know im only by passing the problem doing this and need to get to the bottom of it.
    I am spending an absolute fortune and getting nowhere there is no fault codes coming up on diagnostic machine,the guy who done the starter on friday thinks it is the injector seals are worn and not getting enough compression to start when engine is hot,that all sounds real but my question is if it is the seals worn then how is it if im disconnecting the coolant temp sensor the car will start no problem,if the seals are the problem then why would disconnecting the sensor have any effect and would it not mean if the seals were the problem then the car will not start warm regardless of coolant switch been connected or disconnected?if there is a air gap created from worn seals surely that air gap will not suddenly seal if im disconnecting the coolant temp sensor?i can not afford to keep trying things and to be honest no sane person can keep pumping money into the car hoping the next fix will solve the problem,can someone please advise or help if have experienced this before ?The car is running perfect apart from this problem and literally came into it overnight,26 yrs driving i have never encountered such a challenge lol, Thank you for time to read big rant ,i don't think cutting wire looms and by passing the coolant sensor into tricking the ecu to think its cold starting is the answer,surely the underlying problem needs to be found?The big problem is i do alot small runs for my job so this is causing havoc
  2. Re: hot start problem 1.9tdi 2009
    1836 Post(s)
    You need to check the cranking rpm exceeds 280rpm, disconnect the head harness and view the RPM in measuring blocks but the diagnostics will take a few seconds to come back up so you just have to keep cranking.
  3. Re: hot start problem 1.9tdi 2009
    Jul 2020
    ireland
    Do if it is not cranking above 280rpm would that suggest a new starter?was it a mistake to get a reconditioned one i wonder?thank you for the reply
  4. Re: hot start problem 1.9tdi 2009
    Apr 2018
    N.Ireland
    9 Post(s)
    you can ecu flash a hot start fix which gives more fuel at higher temps
  5. Re: hot start problem 1.9tdi 2009
    1836 Post(s)
    Quote Originally Posted by skodabeast View Post
    Depends on who did it, many are ****... I will only fit genuine Bosch exchange units.
  6. Re: hot start problem 1.9tdi 2009
    Feb 2020
    Bradford
    40 Post(s)
    Its worth checking the wiring loom for a rub through. Check under the airbox, between the radiator and gearbox area
  7. Re: hot start problem 1.9tdi 2009
    Jul 2020
    ireland
    Hi all,turned out timing had went a little off?had belt done 2.5 yrs ago
  1. hot start problem skoda octavia 1.9tdi 2009
    By skodabeast in forum Octavia
    Last Post: 06-07-2020, 12:58 PM
  2. Cold start problem intermittent touran 1.9tdi bxe
    By watchsapart in forum Touran - Sharan - Caravelle
    Last Post: 12-04-2015, 10:57 PM
  3. 2009!1.9tdi and DPF?
    By Mike McKinstry in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-09-2014, 07:50 PM
  4. audi a3 2009 1.9tdi service light reset problem
    By chris96a4 in forum VCDS - Help Requests
    Last Post: 06-05-2014, 04:13 PM
  5. Help! Cold start problem 1.9TDi (PD130)
    By sinso in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2007, 06:41 PM
