Thread: Which 6HP19 gearbox? Which ATF? A6 C6 Allroad Quattro 2008 -
  1. Which 6HP19 gearbox? Which ATF? A6 C6 Allroad Quattro 2008 -
    Jun 2020
    Bath
    Hi All, I'm really confused.
    Firstly: Although my registration is 08 (2008) the vin says car was made in 2007. So when I enter my reg in lookup boxes is this taken into account? And, more importantly, when on ETKA do I use the vin year or reg year?
    Because:
    Ive consulted various ETKA sources on the net and I get a two different responses for gearbox oil. 7Zap says my tranny code (KHB) is a 6HP19 box and for my year the ATF is 060 162 A2. Great, but then on another ETKA source, (ilcats.ru) the same gearbox for the same year gives two! 060 162 A2 and 0551 162 A2 D>> 14.3.2008. Which I take as up till that date. ! Then there are other forum articles that say we have a 6HP19A boxes which ZF give different oils for. Whew... enough to drive one to the local Audi garage (joking!) So how do I find out which one it is?
    BTW my tranny oil has never been changed.
    I really have read many many entries in this and other forums that all serve to confuse me more. Thanks in advance for any help
  2. Re: Which 6HP19 gearbox? Which ATF? A6 C6 Allroad Quattro 2008 -
    bristol
    10 Post(s)
    I believe the facelift model had the different oil than yours.
    I contacted millers oils with my vin/reg they sorted correct spec. Much cheaper oil than ZF and recognised supplier so not cheap rubbish
  3. Re: Which 6HP19 gearbox? Which ATF? A6 C6 Allroad Quattro 2008 -
    Aberdeen
    63 Post(s)
    I think oil type also depends on the software. There was an software update for this gearbox and needed a different spec of oil afterwards.
  4. Re: Which 6HP19 gearbox? Which ATF? A6 C6 Allroad Quattro 2008 -
    Jan 2021
    Norway, far north in the cold
    My A6 Allroad is 2007 model pre-facelift, but delivered in 2006. It has 6HP19 without sw upgrade and uses ZF6 atf oil with Audi specs G055 005 A2 (yellow color) . If yours is upgraded with software it should use ZF8 fluid G060 162 A2 (green color). When I seek in all parts stores etc using my VIN nr, all says that I should use ZF8, G060 162 A2, but not before I upgrade the software.
  1. A6 3.0 tdi Quattro 6hp19 service kit
    By quattrogary in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-02-2020, 10:32 AM
  2. Please Help A6 Allroad 2008 suspension
    By Confused in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-07-2018, 10:14 PM
  3. Question Allroad C6 (2008) air suspension reservoir.
    Last Post: 02-04-2016, 03:47 PM
  4. 2008 Allroad, new to me...
    By Daveym in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-12-2014, 08:18 PM
  5. 2008 Allroad
    By Z900 A4 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-08-2012, 08:34 PM
