Thread: Polo charging issue
  1. Polo charging issue
    Jul 2020
    preston
    Afternoon all, wondering if anyone can shed some light on an issue with my dads polo. Recently he has noticed the battery seems to not be charging when the car is running. Its a fairly new battery - taken out the car and given a decent charge and tested to make sure it holds its charge. The alternator has been taken out and taken to a local centre and tested, and we were told its fine.
    We have tested the battery in the car with a multimeter and voltage was at 12.6 with ignition off. Start it up and the voltage jumps up to 13.5 or so then it starts dropping and settles around 12.3v. We have tested all the ground points we can see (tested 4 or 5 in engine bay) and they all seem fine. Someone told me to try an ac test from alternator b+ to a good ground and we are seeing 24v ac current. Now to me that would say the alternator diodes are faulty? Just wondering if their are any other tests we can do to see what the problem is as when the 'professionals' tested the alternator they said it was fine.
    If its any help its a 02 plate 1.4 petrol engine BBY
  2. Re: Polo charging issue
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    If it was a modern car with stop/ start I would say that was normal.
    But as you have stated it is 02 reg it will have a normal charging system that should charge the battery all the time the engine is running.
    If the battery is already fully charged the voltage should be over 14v with the engine running.
    So it looks like your alternator is goosed.
    As a last check, check all the connectors at the alternator are clean & fit well.
    Connect your voltmeter on DC between the thick output terminal & chassis, check the voltage with the engine running.
    If it drops again below 14v you can be fairly sure it needs a new alternator or perhaps just the voltage regulator ( which is part of the alternator & usually available as a spare part.)
    If the voltage is good at the alternator then you need to look for a wiring fault on the thick wire from the alternator.
  3. Re: Polo charging issue
    108 Post(s)
    1816 Post(s)
    I would also say it is the alternator.
  4. Re: Polo charging issue
    Jun 2021
    West Midlands, Uk
    Did you get it sorted and if so, what was it in the end?
  1. Alternator/Charging issue
    By Alex.02 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-04-2016, 12:37 PM
  2. 2.7t charging issue
    By Rwkshaw in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-04-2014, 12:51 PM
  3. Replies: 4
    Last Post: 01-06-2013, 03:49 PM
  4. Please Help Charging Issue.
    By Blackrat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-11-2010, 12:24 AM
  5. IPOD Charging Issue Golf GTI
    By gibberbibber in forum Golf MK6 - 2009 - 2013
    Last Post: 15-11-2010, 01:30 AM
