Thread: ABS Sensor Issue
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: ABS Sensor Issue
    Feb 2020
    Bradford
    40 Post(s)
    Also double check if m16 is the right bit to use, iirc on mine they are M14 but m14 doesn't fit at first and that's when you have to start cleaning the bolt out. Sorry if it is m16, but that's how I remember them.
    Edit:sorry I was thinking of the front. Had a look at rears and they different altogether
  2. Re: ABS Sensor Issue
    1841 Post(s)
    The stuby design with a hole in the end tried to kill me by shearing right at the end of the 180 turn so I bought a genuine one, yes XZN18
  3. Re: ABS Sensor Issue
    Nov 2017
    Newmilns
    New socket arrived - however it was the same as the halfords version in appearance ( not sure about material strength however) . To support the breaker bar and keep it tight to the bearing to reduce slippage - I routed nylon rope through the bearing bolt eyes and the the bar to make it as secure as possible while trying to break the torque ( used a long steel pole for extra leverage as well) - success - I now have got both bolt & bearing removed. New sensor & bearing ordered. Just need to get the old sensor out ( due to hex hole being damaged - battered a 9MM socket over the retaining screw and managed to get it out - need screws ordered in case not one with the new sensor). Progress is slow but I will be an expert with all the right tools if any other corner goes bad .
  4. Re: ABS Sensor Issue
    Nov 2017
    Newmilns
    I am going to ask a dumb question - is it just a case of fitting new sensor & bearing - ie There is no fancy coding stuff to do with the ECU'S etc - I have VCDS logs from original parts + VCDS software - but not sure how to go about using the software if anything needs changed/updated .
  5. Re: ABS Sensor Issue
    Nov 2016
    Ireland
    14 Post(s)
    Yeah, you can fit a new abs sensor and a hub bearing abs ring assembly without having to use VCDS or anything after.
  6. Re: ABS Sensor Issue
    1841 Post(s)
    Just fit, clear the codes and drive.
  7. Re: ABS Sensor Issue
    #17
    Nov 2017
    Newmilns
    New sensor and wheel bearing arrived from ******* ( much cheaper than euro or carpart4less - although it was about 7 days for them to arrive from ordering - saved ~£50 ) - both fitted and now have a working ABS sensor & Ring - This should now be enough to get it passed its MOT - just need to worry about the EGR fault which gets logged intermittently.
  8. Re: ABS Sensor Issue
    #18
    Nov 2017
    Newmilns
    Car passed its MOT - no problems with emissions - just need to hope EGR fixes itself through running - else looking at expensive repair
  1. Issue with 2019 Q7 50 TDi - Hesitation from speed sensor issue
    By marcusjames in forum Q7 - 4M Forum - 2016 -
    Last Post: 07-02-2020, 06:01 PM
  2. Please Help Dpf sensor issue?
    By Audi2011 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-12-2018, 08:01 PM
  3. reverse sensor issue
    By petrolhead63 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-04-2013, 04:42 PM
  4. a6 oil sensor issue and airbag issue
    By 2400 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-12-2012, 11:26 AM
  5. Parking Sensor issue ?
    By vwnige in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-10-2011, 03:01 PM
