Thread: DAB Module
  1. DAB Module
    Dec 2013
    Liverpool
    10 Post(s)
    Has anyone had any issues with the DAB Module failing? I have tried another aerial but with no improvement so am now thinking the module is failing and what I can expect to pay.
    Part No 4E0 035 563
    KE1276V7700487
    Y07-9622-73
    Or can anyone suggest an alternate part I could fit.
    2007 2.7 SE quattro saloon
  2. Re: DAB Module
    Jul 2013
    76 Post(s)
    My 3G DAB radio cuts out quiet alot.
    The things that i tried.
    1. Replaced the antenna with aftermarket a test to see if it was the antenna, made no difference.
    2. remade the Fakra Connections still no difference.
    I suspect the radio has life expired electronics which cause the issue.
    I also drove the wifes car to the same to the same place that i get regular drop outs and her DAB stayed constant.
    I live with it at the moment as its not too bad.
    If you are getting no Fault codes then it's most the radio has a dry/cracked joint in it or a component failing.
    This one for you is not too bad of a price. Just check the sofware version is the same.
    Audi A5 2008 Other control units/ modules 4E0910563C VAL43671 | eBay
    Dan
    2009/2010 2.0 TDIe SE
  1. locations of mirror fold module & power tailgate module ?
    By Not_Anumber in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-02-2016, 01:40 PM
  2. Replies: 1
    Last Post: 22-01-2014, 10:59 PM
  3. ABS Module: electrically connecting another module while not installed in the car?
    By dansansome in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2014, 04:17 PM
  4. Replies: 5
    Last Post: 15-10-2012, 10:20 PM
  5. anyone used the one-touch module from cabrio-module.de on their A4 Cab?
    Last Post: 01-04-2008, 11:49 AM
